Well a good weekend... lots of positives, the extra power is helping, and the set up is coming along.
Smashed the front bar to bits on Saturday during Team Drift... never mind...
Sunday saw me up agains Kelly McKinnon, It was pretty tight first battle, but unfortunatly my handbrake got stuck on in the second battle and I spun... real bugger as I certainly had a chance... guess that is being chucked in the bin this week and replaced with a proper drift hand brake...
Team drift was fun, although a big smash saw the session canned after only one run.
Can't wait for Eastern creek at the end of next month... new turbo and a whole lot more incoming... stay tuned!
Dan.
  • Replies 215
Posted Images
Nice one Kinks!!! Post up some pics when you get it.
Richard, end of next month... as it says in the last line of the post... but more specifically in case that was what you meant... 29th and 30th of July.
See you all then!
Oh, and thanks for getting my AFR around the right way... I hate going by memory.
The Bel Motorsports sticker is on the wrong way around to be JDMyo
they are supposed to go from the front to the back of the vehicle...
But that is unless you are like Kelly McKinnon who thinks the other way
around is more aggressive looking... Anyway, take it or leave it.
If you look at this truck in my carpark you can see the way it works
with Chinese/Katakana characters... The letters are the correct way
around but go from the front to the back of the truck.
Anyway, congratulations on the results, keep up the good work!
Well development is coming along rather well... now have 224rwkw at a low 0.9bar of boost and at around 155kms in 4th gear. we also made 712nm at 70kms in 4th, and averaged 644nm across the entire rev range!
Which probably explains why I have no 4th gear syncro left. and 3rd gear is spitting out sometimes... I knew it would break eventually... but I was hoping for a little later in the season!
I have 2 dyno graphs, but I'll scan them tomorrow, or next week.
See you all at Eastern Creek the weekend after next!
Cheers,
Dan.
lol... you guys are vultures!!!
If I buy a new box the old one is being kept as a spare, looks like we will be buying a second handy for this round, and rebuilding the old one a bit stronger... especially as we are looking for more power still too!
If I look to sell it Nathan I'll give you a bell. (pm)
Dan.
Did I show you the new Pipe work and Catch can that RoadRunner Fabrications made up for me? Very Pretty!!!
Cooler Pipes
Catch Can
And also someone asked a while back about dyno graphs... I finally remembered to get them... and they are below.
First is Power,224RWKW @ 12psi (0.9bar). We did another run with 20psi (1.3bar) and only made 227rwkw... so it is time for a bigger huffer... BRING IT ON.
Second is torque... again same settings as above, in fact same run! Max 712NM, Min 497NM, AVERAGE across the run was 644NM
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
