I'll be getting my tune done next saturday (the 3rd) in Bundaberg QLD by a guy I've known for years - he worked with chiptorque for six years and has tuned more skylines than I've seen so he should be fine.
That would be stewart yeah??
Edited by 33SOM
  • Replies 109
i didnt have to modify my down pipe at all. My car came with a standard dump pipe, and ive since used an HKS dump for the 2530, and the HKS dump for the 2835 kit and they both bolted up without any mod. but then i must have had a different downpipe originally.
cheers <_<
i hope thats not sarcasm evilution.
ahah nah sorry i like that face it looks cool ;)
sorry, im general interested as im looking to get the same kit for my r33.
What would you advise to upgrade at the same time as turbo?
fuel pump, injectors, ecu, afm? you also mention something about the stock lsd, did u find with the new turbo the stock lsd, couldnt put the power down?
agains sorry for the missunderstand :angry:
lol, i wasnt sure as my last post was a little iffy trying to explain how mine fitted up..
without a doubt, you will 100% need an ECU like an fc, injectors, Z32 AFM and an upgrade fuel pump, and dont forget the clutch.
i found the stock lsd couldnt put the power down with a stock turbo let alone the 2835. main problem was powering out of corners, it wasnt so bad in a straight line, but still suffered a bit.
hmm, I bought my car already modifed and it has one of these turbos, only thing is I've got some custom made dump pipe - its not real flash :P ... can you buy just the dump pipe? Also what intake do you guys use to step down the to the Air Flow meter? Would one of the Apexi power intake kits with a 4" to 3" silcon hose work?
cheers
hey guys,
just wondering how much you both pay for the kits landed to your door if you dont mind me asking?
also, is the actuator rated at 1.2bar? If so is it possable to run lower boost like 0.6bar with a ebc and on that note how would you connect an ebc to the turbo, as its got 2 outlets; one on the turbo and one on the actuator do you need to get a T picese?
Cheers Michael :P
The wastegate actuator arm on my kit is adjustable - I didn't play with it though.
As for putting a T-piece in - we just blocked off the boost outlet for the wastegate and used the factory after intercooler boost outlet as we were worried about the Apexi boost control solonoid getting hot air directly from the turbo (probably would be fine).
I'm running 1 bar boost so not sure how you would go trying to run less but probably would be no worries.
Also I wouldn't get the dump pipe from Japan - it wasn't as well made as my original one - you're probably better off getting one made locally.
Cheers
SLY so you got that power with no modified internals?
i made 266rwkw on stock internals with 2 pounds less boost. i then dropped in a built motor with forgies for piece of mind, and added the poncams at the same time and made the 281rwkw. The stock motor wouldve easily made the power with just the addition of cams.
like all the HKS stuff ive had, the dump supplied with the kit was of awesome quality, why didnt you like it? it might look a bit crude where the wastegate pipe merges (looking inside the base of the dump), as it looks like flow will be impeded by the main pipe, but it seems to work fine.
Edited by SLY33
sly when does your boost come on and does it pull as it winds up
i dont know when it starts building but its pretty early, full boost by ~4grand.
does it pull as it winds up? do you mean as it builds boost is it still pulling? yes it does, wouldnt it have to?! Acceleration is still plenty for overtaking etc even when below 4 grand.
The dump is well made but:
I didn't like the dump for that reason - the lip where it joins the main dump must be a restriction and also my locally fabricated dump had a pipe extension from the dump turbo flange right to the turbine outlet - ensuring the wastegate/turbine gasses are totally seperated.
Another interesting point is the wastegate can only open about 10mm before it hits the dump - I don't know how it'd go it trying to control boost on a larger capacity engine. ie rb30.
I'm sure it works fine but I think it could have been done better - I wouldn't be sourcing it from the other side of the planet.
Cheers
:O i see 1.2 bar by about 3500rpm ..... what size cams have you got? I would have thought mine was laggier cause i have big cams - 270 with 10.25 lift ...
look at my dyno graph supplied and see how it compares with yours. you will have to convert speed to rpms. the ~ is the point in my post. "about" 4 grand. i dont watch the tacho and boost guage simultaneously (my boost guage is in the glovebox and used only to check boost occasoinally by a passenger), nor do i have a dyno sheet with rpms. when im flat to the floor im more wathcing the road than anything else but i know that when the needle hits about 4grand its pulling hard.
what does yours make peak with the 270 10.25 cams? mine are only 260 8.8's.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
