  • Replies 85
Posted Images
I did it today and the noise is good ppoorrsshh but I miss the pphhsstt.
What will happan if I disconnect the return air(from bov to mouth of turbo)and let it free to the atmoshere,will it stall and piss fart around and will the noise be louder btw it' a RB20.
Can you submerge the outlet in a glass of water, then blow thru the small hole next to the valves diaphragm. Do up see bubbles
Im curious to know if the OE BOV has a check valve in their somewhere. Or have you checked that irresprective which end your blowing in, air still passes thru.
Good find.
Good find.
G'day Roy,
Yepp, it flow's both ways. I checked this out just to make sure. Strange hay. Not sure what it's meant to do like it is, maybe it makes the transision from BOV closed to BOV open smoother or something? I don't know... But mine does feel a bit snappier while on boost.
R31 Power - if your ECU is anything like the ECU's on the R33 and R32's then you might get the stalling and overfueling problems that some of the other blokes have had went they run a BOV that vents into the air. :)
  • 9 months later...
Well i cant say i am a fan of this idea. I tried it myself and u can notice its doing something different. I noticed when adding slight throttle from say a cruize situation the accelaration is upped as the bov cant leak excess air back into the chamber. This is i think a not so good thing. Didnt notice any differences in performance when in full throttle position though. I went to the track with it blocked off and on my last run unblocked it, taking it back to stock and i ran .4 of a second quicker. Not sure if the 2 are related but i am not convinced this mod does anything sufficient
I also tested this mod the other day on my R32 GTS-t using a piece of tape to cover the hole, the BOV definitely sounded different....For a start - less air recirculation sound when the turbo spools up, normally when venting the BOV sounds like this: WWTTSSSSSSSSSSSHHHHH, afterwards it sounded the same at high rpm/boost but on a light to midrange throttle backoff it would flutter (kinda like this: TSHH TTTT TTT TT) and caused the motor to hesitate slightly.
I removed the tape and the hesitation disappeared and the BOV sounded as normal - so I can't say I was all that impressed with the result, but it is interesting how different ppl have had totally different results!
I did the mod and my BOV sounds pretty different. Not a long pssshhh anymore. More of a quick sshtt and thats about it. Doesnt sound as nice. But it does certianly hold booster better. I'll be leaving it modded!
Guest RedLineGTR
It's not actually a leak....Nissan put it there for a reason. Did any of you happy little modders find out what it does before you changed it..........Just curious... ;)
From what i have noticed and heard also, it is designed to stop boost hitting so hard when it kicks in gives a more smoother boost delivery when boost is created it does it by bleeding abit of the air.
i really want to do this mod but whats the conclusion result? should i or shouldn't i?
I think it really comes down to personal taste and your driving style.
Some people like the way it feels once modded, others don't.
The biggest difference I found (in my car) is that it seems to come on boost harder and a bit faster.
When I had the car on a dyno, the operator was supprised to see my car having useable boost at 1800rpm !! And looking at the dyno printout, it goes from 46rwkw at 60km/h (4th gear) to 90rwkw at 78km/h. That's close to double the power in 18km/h - I better add in a comment that I'm not interested in the actual amount of power, but it's the power curve that is interesting, otherwise I know it's gunna start up that "can't trust dyno's" crap...
And all I had was a 3 inch exhaust, FMIC, 12psi and the BOV mod.
So as you can imagine, having more power lower in the rev range makes the 'power band' bigger. Well that's my theory anyway.
One question I do have though, some people have mentioned that doing this mod takes away the linear feel of the throttle. Does that mean that everyone that has a after market BOV that plumbs back get's the same results?? I've never used one so I wouldn't know.
J
  • 1 month later...
yeah i have changed my mind, i did this mod again out of pure boredom at home, and have been monitoring it, i notice its more snappy onto boost, and not asmuch throttle needed to continue motion. Liking the noise too.
That's great news freebaggin - thanks for going to the effort of doing a comparison.
J
Thanks to you for sure, I had basically forgotten that the stock BOVs leak and your post promted me to do something about....fantastic result for the cost and effort involved!
Freebaggin, very interesting stuff indeed. Btw Im interested in seeing the boost curves. It seems as if the latter run was running a smidgen more boost, well just seems like it anyway...
Good stuff!!!
Good stuff!!!
Well I suppose it's more that the turbo might be running more efficienctly as well, not having to increase shaft speed to counter the bleed of and as the boost chart shows, the curve is a smidge more consistant and maybe that's all the turbo needs to provide better grunt..???
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
