Hi, i just bought a 89 R32-gts-t which has some major heating issues.
I've already spent a bit having a full service done and a couple of other things to try and fix this very annoying problem, but before i go and throw some more money at it i thought i should ask what you guys think it is.
It basically is always over heating even in the cold morning after 5 minuets of driving i can feel the heat coming through the floor and after a little while it starts to lose power then get it back very quickly making it bunny hop, it mainly starts to do this as the boost pressure rises above 2 pounds, but some times this problem will come and then go away but it seems to be getting worse and happening more often, also sometimes if i slam it for a bit it will go away for 30 minutes or so,When i slow down to take a corner or sit at lights it will stall sometimes and when i start it, it will rev up to 2,000 revs then bum out to 500 revs and keep doing this over and over then stall again.
I've already flushed the radiator twice and replaced the thermostat but it's still doing it.
In the next few days I'm going to get the temperature sensor replaced in a effort to try and fix the problem, the temp gauge wont go above half way even when the motor is so hot it wont start so maybe that is why it is doing it, i dunno.
If anyone knows what this is and how to fix it please let me know.
Have you checked for any leaking hoses or loose piping. Maybe cracked vaccum lines or water hoses. Is the car losing coolant?
Checked ya plugs?
Checked ya coilpacks?
Fuel Pump?
Fuel Filter?
What was changed or done at last service?
It did have a cracked hose that was leaking coolant but i got that fixed, i also replaced the temperature sensor just in case the computer was getting wrong signals, i had the computer checked for errors and it said there were non.
Yea the plugs got replaced at the service, The coil packs weren't touched in the service, But as for the fuel pump and fuel filter i didn't think to get them replaced, I'll get them done later in the week if you think it might fix it.
But as for the water pump i don't think there are any problems there because since i had the thermostat replaced i can see the coolant flowing through the radiator nicely.
Edited by Seb,
It was leaking near the firewall, but since i got it fixed i haven't noticed any change in performance or cooling, It's still running pretty hot.
The biggest problem besides all the things that have been happening, is that it doesn't always do it, So when i take it in to get it fixed there's nothing wrong with it.
Maybe the car is running lean and thats why it's over heating, Don't know how that could be because it go's through heaps of petrol, Just a thought.
I'm going back to the mechanics on Wednesday when i get payed, So what should i get done first?
Edited by Seb,
Jeez man, I got a friend with a SR20 180, same problem as you describe. The biggest problem is when we take it to our mechanic, the car doesn't act up - mech thinks we're paranoid. I went to hook up my diagnostic computer and it didn't do it then either! I have a theory, there might be some crud in your fuel tank, because It always seems to happen when he is very low on fuel. Try filling up to the brim and see if it goes away.
If we fix the problem on the 180, I will try and remember to post it here.
Overheating R32's... how I loathe this problem...
Dude get the radiator core checked - This was the main culprit behind my overheating issues - it corroded from the inside out, hard to spot..
Also check your heater core - look for wet floor its a tell tale sign...
farked thermostat won't cause overheating - they rarely fail while they are closed.
Are you losing coolant each time??
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
