My car gets everything done at Hill Motorsports in Castle hill. Mark is a mate of mine and i think a few other people on this board go there too.
He does good work and damn good prices... he's always got sweet ass cars up there getting something done.
Hills - 8802 0777
Christian.
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-20418
I ended taking it to online performance in Hoxton Park, where AIR the former owner used to take for servicing.
I did a full service basically everything got checked and all fluids and filters changed , and also i asked to get the spark plugs they said that it problay would'nt be required since they are platinium I thought jsut get everything done, lucky cuased it turned at the the sparks where not paltinium, and where basically gone.
They also gave me a written report on what was done and a list of problems that would have to looked at probaly on the next service, (brakes and left front shockl)
The thing i liked was that they gave me options on what i wanted, eg when it came to the oil they asked what type of oil I wanted etc.... and they also washed the car for me (bonus saved me doing it needed a clean)
So I would recommend Online Performance
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-21916
Spiderman,
I may as well add my input here :P I will be having my skyline serviced at Hybrid in Artarmon.
Reason?
After a poor experience with another workshop on my previous car including failure to disgnose a serious boost problem, car running poorly etc and me getting fed up with hearing the words "she'll be right" i went to see Roger at Hybrid....
I dropped the car at 8am, was dropped to the closest station by one of his staff, they carried out exactly what i asked, found the problems i mentioned straight away, asked me to call them once i got to the station after work, picked me up again and drove me to the workshop. Roger then showed me 3 dyno sheets, explained what they changed, what they found etc, showed me the root of the problem and ask if i was happy with that BEFORE they charged me anything.......
Professional Service, helpful and conveinient..... thus i will be going back....
Hills is also good but like ONARUN its a bit far especially when i work near the CBD.
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-22072
BY BY,
Where abouts is Hybrid at, also sounds like another good place to take our skylines, alot of dodgey places out there so i think its good to know where the good guys are.
Nothing worse than paying your money over and thinking yuor getting things down and it doesnt, i ahve a friend who is machanic for Ford, and he tells me storys for example how they thrash the cars on test drives sometimes when there bored, and if there flat out they dont change the oil filter or change other fluids that where in joba and stuff like that, the customer is none the wiser and still pays for it :P
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-22090
Hi Everyone,
Well i dont thnk i should start another threads about this but its that time again, my car feels like it wants a service, a nice full one at that & i want to do the service myself this time around.
Can anyone tell me what needs 2 be changed around, replaced etc.
Im not trying to be cheap, i just think i can learn quite a bit about my car if i did it myself.
Thanks,
Joe.
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-22307
Brendon.... yes UAS is good...
Spiderman: Hybrid is in artarmon
Ultim8DTM5: not being rude mate.... but this for recommendations... if you want to talk about who NOT to go to for whatever reason, do it on another thread.....2 of my friends have had serious cars built by hybrid, one is in progress.... but lets not get into that.....
and the topic is servicing... not rebuilds.
:uh-huh:
https://www.sau.com.au/forums/topic/969-skyline-service/#findComment-22537
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
