Hi guys, as you see in this thread - http://www.skylinesaustralia.com/forums/in...showtopic=89613
I didn't make my goal power target. I missed it by quite a bit. We've narrowed it down to poor fuel. Up in north QLD here, mackay doesn't have anything better than 95 octane.
Now to battle this, I am going to look at some sort of Water methanol injection setup. Its seems to be the cheapest option in the long run. I mean I could ship drums of 98ron up, but when my car burns a tank in 200kms..that would be painful.
Also, constantly adding toluene would be expensive and a pain in the ass. The shit is getting expensive.
I've worked out - water methanol injection once set up would cost rougly $3 - $5 a tank extra. (200l Drum of Methanol costs around $200) and 5l of distilled water is about $4
Talking ot my friend that has a 375rwkw supra here that had to switch to this system, he uses 3l of methanol and 3l of water per tank of fuel. He gained 100hp (or 65rwkw) out of it. Now I know that I am not going to make this kind of power extra, but I'm gonig to be able to reach my target safely, and increase the life of my engine.
ok...theres all of my justification. Now the good part - The setup. These kits are a piece of piss - pump, wiring, jet, sensors etc.
The kit my mate has, has got a maf sensor, and increases nozzle pressure as the boost increases. This would be the best type of setup imo. here is the site where he got it from - http://www.full-throttle.com.au/Engine/stage2_MAF.htm
I really would like some input here guys, as I really need some help here, I'm one of the few that isn't as lucky as you guys to get 98ron fuel :P
SK, you better drop some info if you have any here....or I'll blow up your mailbox..hehe jokes..
so yeah.... Discuss!
i know of a 200sx in melb that uses it, they were able to dial in 1 or 2 extra psi with no extra detonation or knocking. i feel there is more to your power being less than we currently know, ie: exhaust, fuel pump, afr's etc so water/methanol might not be the be-all endall solution. again great idea, hope you sort it out
There is heaps of information here>> http://snowperformance.net/ Their kits although expensive are very highly regarded especially amongst the big horse power turbo diesel crowd. Hope it can help you somewhat.
the 200kms per tank id the first 10 load points on the maps, which haven't been tuned yet. Its only been given a full throttle tune.
Thanks for your input 68charger, the link I provided is the exact same kit I have linked. Must be pretty popular unit by the looks.
And I do think the problem is fuel, as I've had about 5 people tell me now that the switch from our dirty 95 to 98 run gave them up to 30rwkw in some areas.
Just remember guys that its very hot and humidup here. Today is close to 35 degrees.
Paul, its not the exhaust........ its huge, there are no restrictions. Its detonation. Detonation caused by bad fuel and hot weather. I wish we had better fuel...
Edited by The Mafia
200kms a tank - you sure your injectors and everything in your fuel system is up to spec. My R33 running on an untuned PFC (so should be rich) gives about 400km to a tank at least. Slightly more than standard ECU but not much.
Is 200km when you are on the hammer?
Injectors not giving out a nice fine spray or a clogged fuel filter could contribute to the pinging.
my pfc also gives me about 220km because its not tuned for fuel eco either...
you might also want to checkout http://www.coolingperformance.com.
Theres a guy on NS.com whos a distributor for them.. its about $400 and comes with a pressure switch to active at a certain psi, and also an alarm for when the water/methanol etc is running low.
Yeah what about just a spray nozzle and a water cooling setup for the intercooler. Cheap to setup and may bring the inlet temps down slightly. All you need is a washer bottle and a spray nozzle and a switch.
Sounds like you may need the extra octane though...
nah, that method does like 2% difference.. Hardly worth it I reckon. And having it running all the time? I'd need to fill it up every second drive..
The one I am looking at has its own maf sensor, and will start th nozzle at a specified boost, and slowly increase the pressure as the boost increases. Its probably the smartest unit I have seen.
200km's per tank is way way too low.
I'm still running the rb25det base map with my 3ltr, I use up to load point 13-14 for general driving before boost is made, once on boost its on to load point 16-17. The last tank of local driving (mostly 60km/h in to town etc) I managed 451km's. That was on ULP (due to lack of bp and mobil 98 fuel in SA + it helps me keep of it as its not tuned).
If I'm stuck in to it with 98 fuel then I see around 380-430km's per 50-53litres.
Rip the injectors out, get them flowed. It may be why you are unable to run any decent ign. timing. One may be stuffed causing only one cyl to ping.
Edited by Cubes
Yeah 200km is woeful. On base map mine will do about 450km to a tank. Check your load points, 02 sensor, maybe you have a leaky injector.
Cubes - do you think ULP is fine if you don't hit the accelerator hard ever. Just thinking if you knew you werent goign to hammer it for a week or 2 and jjust driving round town off boost most of the time would it be ok...
ULP is fine in mine providing I dont run over 6psi.
So basically I keep it off more than that boost.
Mines not tuned so I really don't like giving it a bootfull as at around 5600rpm its going lean, sometimes I can't help myself in first and second if its running 98.. So I fill it with ULP and it forces me not to boot it or load it up excessively at low rpm (1500rpm in say 5th gear trying to climb a hill) :D
The 3ltr its quite good in traffic, I can take off quite quickly and be well ahead of the traffic changing gears at ~2500-3000rpm with light throttle and no boost.
I obviously run a PFC so I can keep an eye on detonation.
This is heading off topic.. .Sorry Mafia. :P
Edited by Cubes
Oh yeah - sorry Mafia. Yeah I try not to give mine too much either as Im not sure on the AFRs etc. Set rev limit to 5500rpm and try not to give it too much.
There's just no way you should be only getting 200km to a tank!! That must be so expensive to run. I'm annoyed when I only get 400km to the tank. Last car was a corolla 4AGE so I was spending literally half on petrol compared to now (Used about 7L/100km of regular vs. 12L/100km of premium). Hopefully after the tune I will average close to 10L/100km.
The tuner reckons these cars (R33s) should get 10L/100km
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
