i like the work you have done but whats with the valves?..are they standard?
heres what a good head job looks like,i hope this helps a few if there thinking of doing head work.
Hey this is very nice. Looks the the quech area has been rounded off for the valves. I've seen this before, I'm impressed. Anyone else seen this stuff before?
  • Replies 315
not sure, as the gearbox wont shift above 9k rpm and i need oversize pulleys to prevent blowing the air con compressor up and to slow down the power steering and water pump (n1 which flows less already so might get hot in traffic with an oversize pulley and cruising speeds)
i think the need for over 9k rpm wont be very often as it is going to be a street car and not a drag/track car, so i need it reliable in traffic as much as possible, i have another daily driver, so wont be drivin it more than 1-2 times a week for cruises on weekends, or maybe the occasional thrash after work :O
the tuner i am using, does race/rally cars, and high power street cars, currently his best hp is just under 700hp at the wheels from an evo 6 i think (2L turbo)
just sorting all the fuel lines at the moment, and god damn they are pricey  ;)
spent $400 on turbo braided lines for water and oil
another $350+ on fuel lines and fittings
and i still havent got everything yet.  B)
cheers
Brad
Hey Brad,
I know what youre going thru with the braid and fittings; i must have spent about $1800 at earls this month on water, oil and fuel fittings!
Ive done a bit of research, and ive found that the teflon lined braided hose from Earls (Speed Flex its called) is the go for fuel. Everyone ive spoken to who have used normal braid have ended up with terrible fuel smell in the boot or cabin. If youve got the earls catalogue, you'll see that they have disclaimers everywhere about the use of high octane fuels with their conventional braid. Also, the Speed flex is graphite (?) lined so as to prevent the built up of static electricity. The braid is about $6/m more and the fittings are about 20 - 30% more but i feel its worth it.
Or they sell aluminium tubing that can be formed into shape for fuel lines with aluminium tubing adapters.
Just a thought.
Shaun.
Hey Brad,
Just a thought.
Shaun.
yes ive used the teflon fuel braided line and fittings to suit :) thanks for the warning :) total ive spent now is $1200 on fittings and line for water and oil lines for turbo, fuel lines and oil filter relocator. looks the goods but ;)
also my valves r stock sizes.
i had the guys at rams head service in windsor in sydney do the work for me,they also did the head for mario(gtr-700),when the guys at jun seen the work they were inpressed,i supplied all jun gear,there cost of machning,assembly match porting the plenum,seal and settings,flow test,the lot was $3800,some would say thats alot but i think for the figures it produced im more than happy.
Wow all the pretty pics, but the real question is what does it flow
its about a week from being finished and ready to book it in for the initial run in tune :huh:
heres a few pics of some interesting bits....
this is the coilpack setup with 6 msd coilpacks mounted under the coil cover neatly
heres one of the cooler pipes in all its shining glory, polished like a mirror ;)
under the stagea, and remote oil filter setup is shown, and 9L sump
wastegate exhaust outlet pipe vented to the atmosphere :)
thats all for the moment :)
Brad
whats ohh mean?  ;)
its the sound of disappointment.....your last comment was "thats all for now"....so i responded "ohh".....i.e. i wanted to see more.
its getting very close now.
good luck with initial tune and run-in.
hehe, no worries thanx mate, and the oil filter is heaps out of the way above the swaybar almost so its got no hope off being hit as the sump/ xmember is way lower.
only bad issues is i got a stock gtr cooler on it at the moment, and no oil cooler (only 9L sump) so whats the opinions on that for the initial tune/and tune after run in of around 500rwhp.
might get an oil cooler, but im sure the gtr cooler could manage 500rwhp for the moment???
dangerous and risky or what? B)
Yes power levels generate heat but.....its how long and hard you run them for that increases damage/wear. For run-in it wont be needed...we only ran a cooler on ours recently due to the drag calander running events in Nov. and Dec.
Factor in a cooler later as its easy to intstal because you have the relocator.
Are you running a Nismo thermostat ??
P.S. you thought i was having a go at you with the ohh comment....lol
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
