i have been told by a performance place that when putting in rx7 550cc injectors i still require a resistor pack however i thaught that was only for low impedence injectors as rb20 is high, the rx7 ones are also high so will these fit in without to much hassle????
Secondly what is the correct part number?
Last if i install them myself can i drive to a dyno(its pretty far though) i dont have a luxuary of a powerfc but i do have a remap ecu i just need to et tunned once are in?
thankyou :(
https://www.sau.com.au/forums/topic/98328-rx7-series-5-injectors-into-rb20det/
yes. if they have a bosch(square plug) there s4 low impedance
if they have a denso (oval plug) there s5, both are reddy pink.
i thought 20s had a droping resister. factory ones are low impedance any way arnt they?
I would talk to your ROM tuner first, cause I bet they wouldn't recommend the 550cc. And if they do they obviously havn't tuned on them before. Both my boss and I have had trouble with those injectors when tuning factory ECU and I also know that Martin Donnan had the same problems down south, very shite low pulse width control. Rotories dont care because they just drink fuel.
I also agree with rob82 comments as Matt Spry tried tuning them for my last R32 with factory ECU remap and had the same problems. Took them out.
Cheers
I'm running these red tops on my r32 with a remap and they work fine other than a rough idle.
This could be rectified with a bit of messing around with the ecu idle control values but I havent really had much time to do it yet.
wat kind of power can you make before these injectors start to run out of flow?
I think they flow to about 560cc each From memory so about 560HP@flywheel?
As long as the fuel pump is up to the task of course.
well my tuner is not recommeending these as too much mucking around, well a question for u all i have asked red drifter thanks for ur help but, my prob is at the moment car is so shitty off the line after remap i got a fmic,14psi( can xtract ne more with out fuel), hiflowed t3, xhaust,malpassi rising fuel reg, big fuel pump and all the other usualls, would i be better off getting a proper engine management or these injectors to cranck up the boost
GTR injectors (444cc's) are the most common upgrade, you just need to get a GTR ballast resistor pack to go with them. They flow enough to reach the limit of standard RB20DET internals. The Standard ECU (remapped) won't have any problem running them.
:) cheers ;)
Edited by Sydneykid
after a tough choice i thuaght i have heard too many bad stories with the rx7 injectors so i got hks550cc ones(alot more pricey) instead lets hope all goes well. pppft i doubt it
Are they HKS 550cc's injectors for an RB26 or for an RB20?
:) cheers ;)
S5 inj + PFC work fine.
However @ idle even tho it doesnt sound to bad except for the ocassional pop they need to be tune quite rich AFR.
The spray pattern on Rx7 inj is more like a squirt rather than a mist compared to a piston injector so tunnig for them to spray small amounts of fuel(@ idle) its kinda tricky. And hence requires the AFR to be slightly rich. My AFR @ idle was ~ 12.0 when they are usually around 14.0.
Rotaries have a deflector which splits the spray in half for a more even distribution, obviously piston motors dont have these.
Best bet is to go for GTR inj. or if budget allows go for SARD, HKS...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
