The GReddy Profec B-Spec 2 is becoming one of the more popular EBCs around and since I had one installed I thought I'd post a really simple photo guide on how install should look like on a RB25DET engine.
Picture 1
- The GReddy solenoid fully replaces the stock one.
- Black hose from the actuator goes to the GReddy solenoid as shown
- The red hose attached to the GReddy solenoid goes to Picture 2
- Electrics are wired up simply as shown.
Picture 2
- This photo is located at far end of the plenum, next to the BOV.
- The bottom red hose attached to the T-piece comes from the solenoid in Picture 1
- The right red hose goes to the plenum as shown.
- The black hose on the left goes to the BOV.
Picture 3
- This photo is located at near end of the plenum, next to the wiper washer bottle.
- The bottom hose with the filter attached goes to the main control unit inside the cabin.
- Other hoses are put together simply as shown.
Hope this helps some of you during a DIY install.
Edited by Wink
  • Replies 42
Posted Images
just a side note.
The solenoid will not work as effectively if it's setup to receive with the long red hose as shown above. It's best to keep all hoses from the solenoid to the wastegate and from the intake to the solenoid as short as possible.
It's best to drill an attachment into the pipe that leads from the turbo to the intercooler, or the pipe that leads from the intercooler to the throttle body, and grab the feed from there.
  • 1 month later...
If the pressure source for the solenoid (the red hose that Wilch referred to) was tapped to the intake pipe before the intercooler, wouldn't the Profec be controlling to an inaccurate boost level? I was under the impression that there is a pressure drop across the intercooler so if the pressure before the intercooler was say 9psi, your engine isn't really getting 9psi but something less than that.
wilch - Can you also explain how the effectiveness of the solenoid can be different by using the hose from the intake manifold instead of tapping into the intercooler-to-throttle body pipe? Why does the use of a say 30cm longer hose affect it?
  • 10 months later...
I looked at the AVC-R instructions and yes it is very similar except for the whole interfacing with the ECU to use the extra functions the AVC-R offers.
old thread, but im just about to buy a profec b or a avcr, is it worth paying that little extra for the avcr, and can any one tell me the extra features it has buy hooking up to the ecu?
thanx
thanx
It has a bit more configuration options and more information displayed.
Where does it rout through the firewall?
http://www.skylinesaustralia.com/forums/in...amp;hl=Firewall
Mine goes through the driver's side front guard.
haha, the most fun bit. I ran my avc-r wiring through the passanger side hole where the rubber boot thing is. The easiest way to wire through it, is to fold the wires over a blunt flat screw driver and push it through.
Hi,
I've just got hold of one of these profec b spec 2's aswell.
Is there any way of me testing the unit off the car as I bought it 2nd hand and want to make sure its working before fitting it.
For example if the unit is connected and powered up, I then switch the controller off (stock boost) so now I can blow down the "NO port" (the red pipe in your photo) without a problem, when I then switch the unit on though I would have thought I wouldn't be able to blow through the solenoid anymore.. but I still can. Is this normal? does it need to be on the car getting a little bit of positive boost for the solenoid to kick in? or could the valve be defective??
Any info would be greatly appreciated Thankyou :happy:
  • 2 months later...
Old thread, but for any guys still buying these, the plenum is probably not the best place to get the pressure feed from, and it evidently makes the lines a bit too long. I just installed this unit into my car and the solenoid looks like this:
The feed comes from the intercooler return pipe so the engine will be seeing exactly the set boost, accounting for the pressure drop across the intercooler. The only possible problem i can think of is a leak between the turbo and IC, in which case the only warning sign would be the sound of stuff breaking. I'm not pushing the stock turbo hard though, i'd probably recommend getting the feed from just after the compressor if you're going to run it on the edge..
Guess it depends on whats available!
I have mine before the throttle body so passes the 1-2 psi (approx) drop after the cooler, but with a STD turbo, could be pushing it to hard.
Guess, 1. STD turbo, have near the turbo, 2. A/M turbo, have after the cooler!
just thinking :P
I installed one of these on the weekend. The hoses going to the solenoid should be as short as possible as they control the wastegate. As my install was on a stock RB20 I had a nice nipple on the compressor housing to connect to. I then ran the control wires for the solenoid across the firewall and in through the drivers guard along with the pressure hose from the fuel reg/plenum.
  • 1 month later...
Hi guys,
any of you who have done this mod:
Have you also installer an apexi AFC II and an o2 sensor? In order to eliminate lean/rich running and flat sports around 3-6k rpm?
Or have you simply installed this mod without any further problems?
Cheers
Ger, Wales UK
  • 6 months later...
hi guys,
i am trying to install the profec b onto my 33..
I am up to the part where you connect the hose (from the plenum) to the main profec unit..
one problem:
if you see the attached photo, of what its suppose to be when finished:
I.E.
On the bottom hose (with the filter) I already have a hose in this place which goes to my boost guage inside the cabin..
how would i get around this to also connect up the profec line (as its suppose to be in the pic) ??
should I slice another T section .. ? :S
any help would be great, especially from those who have this installed with a boost guage..
cheers.
You can splice in another T if you like, just re-use you boost gauge line and tap it in as far back as possible inside the cabin.
You can also disconnect your original factory boost gauge (at the rear end of the bay-near the firewall) and use that plenum feed for the Profec. The tube is a bit thinner than standard though so you might need another tube but see how you go.
I use the back of the plenum for my boost feed on the Power FC Boost kit and it works fine.
thanks for the input birnie, much appreciated..
i was wondering if splitting a line which is "in-use" could be done, but now to think about it, the pressure should be equivalent in any of the hoses which come off the plenum ..
cheers mate :)
  • 2 months later...
Hey guys i just picked one up today, Just wondering if install this myself, is it reccomended to tune on dyno? The current mods i got so far is stock, mainly just a pod filter and turbo back system...and HKS SSQV, no cooler yet, its currently getin oredered.. but yeh can i just boost it up a lil for now if install it?
Thanks,
Geraus
    • Driveability will be about the same with either externally venting BOV, or no BOV at all. Perhaps worse one way than the other, with me thinking that the definitely more flow going through the AFM through a venting BOV more likely to cause rich stalls than the perhaps more flow that the AFM might read on reversion. There is no such thing as "turbo damage" from not having a BOV at stock, or even quite a lot higher than stock, power levels. You need a big turbo with a lot of mass spinning hard getting a horrible slowdown from a slammed shut throttle before there is anything like the shaft loads required to damage things. Not an issue on small turbos. The ONLY 2 reasons that Nissan put a recirc valve onto the RB were: It is a bypass valve. It is open when under vacuum. When not on boost, it bypasses intake air forward around the compressor, which unloads the compressor, allowing the turbine to sping more freely, making the whole lot a bit more efficient when just puddling around. Throttle response should also be faster via the shorter, smaller diameter BOV pipe (when in NA, ie before the BOV closes and boost is building) which is nicer for driveability. Emissions. The reversion causes CO pulses. Eliminate the reversion (or at least, keep it away from the AFM) and you don't get that. The stalling/driveability aspect could have been tuned around, as shown one example of by dose above, if Nissan hadn't put a recirc valve on. Many many turbo engines before the RB had no BOV. They did not stall. See the RB30 turbo as an example. Nistune is definitely better than just stock ECU. It allows you to access and change things that are not excellent on the stock setup, and allows you to do mods like put decent injectors in, relocate the AFM, put a bigger turbo or even cams, etc, on, change to coil swith completely different swell needs, etc etc. All the things that you might need or want to do 25 years after the car was new. Aftermarket replacement ECU is obviously better again, because it gives you even more freedom from the constraints of the stock ECU. I won't be needing to go any further than Nistune though, for the new turbo in the 250ish rwkW region I'm going to, with big injectors, and most other things being stockish.
    • Lucky the prp block is supposed to be released next weekend
    • Wow guys thank you very much for the HUGE info :-) @GTSBoy I have like 30 minutes if test drive with that car/engine and it not stalled once. IMO it ran very smooth so i guess it was not that bad(but asi i said it is stock) That atmo BoV is worse than no BoV or in my case or it is/will be the same? Cuz frankly i rather have little whooosh sound than that sututu 😄 But either way the less harmfull for engine/turbo the better(if the stock is not an option right away) Yeah about that rebuild i talk with guy who will be doing swap and custom pipes...i think i can get stock BoV or get aftermarket which will function the same. Yeah i looked at that R35 option and i try ask my mechanic more about that if he knows. The engine has stock ECU but i can get Nistune for it. On that stock it runs quite well...but i have limited time with it so rly dont know. Ecumaster is this https://www.ecumaster.com/  It is not some dodgy backyard ECU :-)  @MBS206 Yeah but it will be better to have Nistune than the completely stock ECU no? About that "same" atmo/no BoV. The drivebility would be the same? I dont know but i kinda guess that amto BoV would cause more problems than no BoV in my case? Or is the same? You just "change" one sound for the other? Yeah i read many many many topic about hurting the turbo. But no one know anybody that would 100% tell that his turbo/engine blows/get damaged by not running BoV. Of course turbo would be little happier IMO if it has BoV ..but if you do not trash i think i should be good. And as you can see iam already trying to get this right...just working what i have right now :-) Yeah iam kinda the same...i dont want nothing loud and frankly iam not liking that sututu noise that much 😄 i rather have little bit of "whooosh" or no sound at all. Of course in my case it si a completely another world when you came tu Turbo car with open air box and no BoV and you driving the N/A ...all i hear is engine. Here? I heard turbo/sucking and that sututu 😄 @Yeetus So in my case it is really no difference to run no BoV or some atmo BoV like GReddy FV2? The car would drive the same and has "the same" little problems? As i wrote above i kinda thinked that atmo BoV with stock MAF would cause more problems...but then again i dont know much about no BoV either :-)  So to avoid stalling i "cant" just put neutral on stop lights like from higher rpm? Or? Yeah iam already looking for ECU :-)  Yes iam at the same side with thar R35 MAF :-)  @Dose Pipe Sutututu Thank you i (my mechanic/tuner) will look into that) Guess iam taking the Nistune at least :-)
    • Here's the workaround with Nistune I was talking about, just add in more timing on the decel table And play around with the fuel cut & recovery, it's enough to stop it from stalling on a decel
    • Hi Apex and welcome!
