My First Skyline's guide to changing your oil and oil filter in an R33.
Guys, after our little talk on the washer the other day. What does eveything use ?
Fibre or Copper ? I have both available but fibre just seems to be the way to go. I previuosly had what looks to be a rubber o-ring which has lasted the distance but not sure if I should be using rubber or not due to heat of the sump.
Any ideas ?
I just did the oil again... and I thought it might be time to change the sump washer, so I bought some fibre ones... anyway, pulled it out, copper washer looked okay, so decided to use that again, and put some of that thin white sealant tape around the thread... so it should be fine.
i just had my oil changed in my 33, by the 'local mechanic', who change the oil (helix ultra synthetic) and the filter Ryco z145a.
i wasnt really happy when he revved the engine at 3000rpm, via the cable in the engine bay, for 10 seconds, so that he could actually take a second reading, which was on 'full' luckily.
i think that it is bad to rev the engine at 3000rpm, when the oil filter is brand new and had not been primed (oil filled before putting on), because maybe there is a space in time when the oil pressure is low as it is filing up the filter (which at my guess is about 400mL), so therefore perhaps there is limited oil and starvation in the upper cylinders when the pistons are flyn up and down at great rate....but i suppose 3000rpm is not all that high. AM I TOO PARANOID, or does this technique suck????
I only got the mechanic to do the job as my 'warranty book' had to be stamped...otherwise i ll do it myself.
If you want to do something right...do it your self.,, is the saying, (as long as u know what u are doing).
Nah, you're not being paranoid. He probably does it that way because the quicker it's done, the quicker he can have smoko, or get onto the next job. You're just worrying about the safety of your car, which you paid for, and not the mechanic. Next time, do the oil yourself, let it drain in when you put the first lot in, let it settle, turn on the engine and let it idle until the oil pressure light goes out... then turn it off, top up and then go for a 10 minute drive.
here something to think about.... i was at BIG W, comparing Z145A's and i noticed that the Valvoline for 9$ was exactly the same as the $3.95 cheaper brand...forget the name, but was in a black box, bottom shelf.... one of those brands which you never heard of,...
i actually compared the outside casing, the hole size, the way the insides are pressed together, the inside of the filter material, you can see the holes and inside guts when you look in the light...and let me tell you guys...absolutely exact,,,,... made in PRC....peoples republic of china....the only difference was the colour...this cheap one was black.... it's funny becuae i remembered that the valvoline used to be a korean product a few years back when i drove a charade.
anyway, i compared the ryco, and there is nothing like it. In the inside the holes are cut differently, and they are more like 'slits', heaps of them, rather than holes. Cost 12$....
I also looked at a 'cooper' brand, and there is no clones, made in korea, sealed with plastic, looks good too.
anyway, somehting to think about.
I've re-used my copper sump plug gasket a couple of times now. It had a bit of a ridge on it, but i sanded it back with some emery. Starting off with coarse grade and progressing to smoother, and it now looks pretty much brand new. It doesn't leak at all.
I prefer copper, I've had bad experiences with fibre washers. They get worn/chipped with age. Re-using my copper washer wasn't me just being cheap, it was mostly due to the hassle of that I NEVER remember to buy one when I buy oil :) So it just saves another trip to the shop in someone else's car, assuming I'm doing the change during office hours.
  • 3 weeks later...
We need filter pics!
I did mine, though when putting in the new oil, i expected it to overflow when it had enough. It swallowed all 5 liters, and when putting the old shit back into the bottle, it came to 4.3l...some ppl say 4.5l for an rb20....but hhmm...think i might go check the dipstick.
Guest RedLineGTR
they say 4.5lt for most skylines...but remember that their is still oil that is left in the engine...so anything from 4.2-4.4lt should be perfect. If you want it always on full put no more than 4.5 lt
  • 1 year later...
  • 4 weeks later...
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
