I know a wood worker if that's any help. Seen him build a couple tables and the like. It's more of a hobby and a profession of his though and he's in London right now. Will be back in Feb if that helps.
Any cabinet makers out there that want to do me a nice deal on a nice custom cabinet??
Can't find a normal one to buy so need to get one made up.
:O
Is to keep your trophy haul in? :)
My brother does this but he is also in the UK and customs dont seem to be such a fan of wood coming into the country unless it is treated. Something about pests and things living in the wood :O
Three of my mates are, but one builds stairs and is too busy, the other two probably would do it but they are getting cocky and asking too much money.
I'd go into your local paper and check out the classified section.
Lots of retired tradesmen who take on small jobs and are really good at what they do, and charge about $25 per hour.
BASS OUT
my grandpas a cabnit maker, he is on holidays now aswell so has time to burn(go into country road jsut jeans ect.... all the stuff in there he makes, no the clothes, all the wood crap)
send me a pm on what you want and ill ask him what he thinks.
What sort of cabinet are you after? Timber or board? My girlfriend is a cabinet maker and came second it the state in the furnishing insustry training awards and took out the craftsmanship award at tradschool. She's made wooden/glass display cabinets, tv cabinets, kitchens etc. Snowy if you want Tash to come for a look or talk to her call me. She does execptional work and won't ripe you off.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
