Hey guys,
have a friend who works for this company that sell jacks
want to know if there is anyone out there wanting a low profile jack witha pair of jack stands
my friend needs a minimum order of 10
and the price will be $230
with the RRP @ $290
Plus shipping interstate from melbourne
which i am recieving a quote tomorrow
i have attached a brochure
Regards
Nick
Ultra_Low_Garage_Service_Jacks_LoRez.pdf
Edited by NiCk-180
yeah linky no worky
how long is the jack
how far from the ground to saddle when lowered right down
how many kg is it rated to?
is it ADR approved?
the price is great :)
I'll take one, can pick up in Melbourne.
Duncan: it has Australian Standard compliance according to the note at the bottom of the brochure, which is what I think you are meaning.
no prolems just send me a pm with your email and il contact you when i have them should be next week sometime
Silver gts-t : the highest point of the jack is 143mm which is at the back obviously
Booster: that price does come with a pair of jack stands
pm me your details if your interested and i'l get in contact with you when i have ten people which is very close now
will find out this afternoon
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
