You will need a 3 inch turbo back exaust( get one of those split dumps from the guy on this forum), fmic(can get a good cheep one from another guy on this forum), a fuel pressure reg and a Power fc ( get it of the same guy that sells you the fmic). Hope that helps.
really cheap?
Chinese ebay turbo dump + 3" exhaust + bashed cat.
chinese copy ebay intercooler
simarks boost controller
Jarcay DFA.
Please note that the dump pipe might split and the intercooler might not flow and cool enough. You get what you pay for. Just save up.
However, simarks boost controller works well, and so does the DFA, if you put it together right.
You don't need an aftermarket fuel pump or fuel pressure regulator.
I have HKS style dump pipe & exhaust, R34 intercooler, K&N panel filter and Power FC with boost controller kit.
Made 207 rwkw (hub dyno) at 0.7 bar (10 psi).
Total cost including tuning approx $3,400 ($NZ)
You pay for what you get. If you do it on a budget you wont get quality..
words to live by
sure the fuel pump doesnt make any extra power, but i woudlnt want to push the stocko that hard, coz if it lets go, your engine aint going to like it
Also helps to see a good tuner aswell
i went from 187rwkw to 201, just because i was running rich as.
I also have
Power FC
FMIC
AVCR
Split Dump
Panel filter
3" hiflow cat
Running on 12psi
Some money spent on getting things were fixing up performance joints mistakes . i have been to APC, FIST, Mercury (just for power run) and Chiptorque,
im gonna try matty Spry next and thats it.
ok ive got a fmic , 3'' cat back exhaust , pod filter , and one of them turbotech boost controller but never turned it up so still running stock , also i got a power fc but still in the box hehe so is a fuel pump that important? i want 2 put a split dump n hi flow cat but if the fuel pump is more important den i should get that first
also it should be important to note that mods based on a $ per kw gain at the start is very high, then as you progress it drops signifcantly. the first few mods are really cheap and give really good gains. then as you progress up the power tree, usually past 160rwkw it becomes more expensive per kw gain.
ie piggyback vs standalone and so on
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
