i was just thinking the same thing. if fatz doesnt get in i'll boycott. i think this event held so much promise, but so far has delivered so little.
also 600hp, do you own a car/skyline? It's just i've heard about your fathers nice GTR and your brothers wrx, but i never hear about your own stuff? just curious. :rolleyes:
  • Replies 503
Posted Images
absolutely, and even if they put a competant race driver in the (as opposed to a drag racer) it stil won't replace years of circuit car development. If the BSM motorsport production car is at 1.09 and improved prod at 1.07 there will not be a bunch of cars at 1.05
The 1.07 is with the mandatory Improved Production 27mm turbo inlet restrictors in place. It would be a bit faster without them, but as Roy said, Wakefield is a handling track more than a power track.
:P Cheers :laugh:
Russ - you suck. Your car is way too fast now.
Anyways - back on topic - Autosalon just called me to say I was in and that it is on Thursday March 30th. I had to tell them I couldn't make it due to Grand Prix commitments.
He did go on to tell me that they would be holding another one later in the year however and I'll get an invite to that. Hopefully it's not on AFL Grand Final day or something.
just got a call from autosalon
sounds like im in
yea baby burnouts
might even have to change the brakes
the brakes russ the brakes
shit im scared i haveent done a hot lap around a track in 2 years... but for teh chicks ill do anything
Edited by fatz
sounds like im in
yea baby burnouts
YEAH BABY!
damn i wish it wasnt on GP weekend, as i'll be in melbourne :D Otherwise i would break out the bikini and come and stand next to your car so you dont look out of place. plus i am heap hotter than most of the models the other blokes hire.
good luck pete. if you dont win just keep driving south to canberra and re-settle there as we wont want you back.
yeah, i think i'm flying down thursday morning. :D
i cant see how anyone else would do a better burnout, but you may find in a circuit battle, that biggest smoke show is not one of the awards on offer...
so do i have to wash my car
it was painted 1.5 years ago since then its had one tub
i dont know if i can bring myself to wash it again
I just received a call to so I am in and accepted. FATZ I will be keeping clear of your shit box doing the smoke show.
john are you scared man? have you driven your car on street tyres?
lolololololololol
just picked up my set of rubber 10 bux fitted and ballanced at ajaj tyre joint for the set of 4
lol
yea baby
man im getting a bull bar for the r31 i heard there was going to be some biffo on the track
Edited by fatz
Did anyone get the name of the guy and a contact number from Autosalon? I'm thinking of changing my mind....
Its 724km's from my place to Wakefield. I reckon I could drive up Wed - do this Thurs and drive back Friday and GP on Sat and Sun. Now that the 300 is in I really want to come. LOL
Do it Andrew, ill talk your ear off for the trip there and back :D
Its definitely goign to be better fun then the few days of practice :)
Bris - looks like Wakefield is open for practise on the Wed. Since I've never seen the track before I might head up on the Tuesday now.
Just have to try and source a trailer and see if I can get the leave passes then it'll be on. Might try and get Chris and entry too. He did just come 2nd in the Calder Rally Masters so he should be good enough. I'm sure he'll be faster than any Zeds there.
How could you miss this one Snowman. Fatz how did they let you in anyway did they need a example or something. You are bound to be a crown pleaser. I think it is timed only event not show or drift, so better change hats or try and reprogram. You Will NOT be popular fi you put dirt all over the track. Actually you go after me would be real good.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
