  • 1 month later...
Hey guys, Pom here.
Is there any info about draining and refilling the coolant system?
I seem to have some very nasty rusty looking water in my Stag and would like some info before i drop it all out.
Just how to refill and bleed the system would be great.
This site is brilliant for Stag info.
Cheers
Sy.
Hey guys, Pom here.
Cheers
Sy.
Here is a picture of the bleed valve - mine has a little tag on it that says "never open when hot(courtesy of SK):
Thank you :)
Is it just a case of taking the bottom hose off and draining it ?
I have seen the little cross headed screw thingy on the rad but after reading how they break then i'd rather take the hose off. I seem to have a little leak underneath the inlet manifold that's dripping onto the oil filter, Is there anything around there that's common for leaking ?
Also what kind of coolant to use ?
I got no service history or booklets with this car ( Big gamble huh !) So im literally flying blind at the mo.
Didn't stop me doing the high boost mod and chucking the Apexi filter on today though .. :P
  • 4 weeks later...
hey all i am new here have a rs4 97 had nothing but dramas since i bought it (not to the cars fault) had some drunk hit me in the rear 2400 for standard bar so the joy begain body kit (from monkey warehouse) all the prep that go's with it and then the fiting was bodgie after hours of work had to go with the best i could do was not happy and the the frount mount done with no effort at all and then the elec boost controller then was happy with the over all performance of the wgn even with the 4-5 coil pack miss unitl now was not that badthis is a family car if the idiot had not hit me it would still be stock execpt cat back. i have 9 month old twins and cant stand commodore's hance the stagea. the miss seems to be the coil packs i only run 7psi in it as i cant go any higher has any one fixed this prob with just new coil packs or do i just go and get fuel cut as well would like to run 10psi or higher (for when i am on my own) i am prepared so spendthe money for coil packs but that is it as it needs new suspension and need to save mu pennys
i would also like to thank everyone for this godly place would still be licking wounds if it was not for all the info found hear when ever i am in doubt i come STRAIGHT hear and find much comfort..
again many THANKZ to you all
will give my system a flush now
Coil packs are expensive. have you checkd your plugs? Get a set of coppers gapped to 0.8mm (NGK BCPR7ES-8 are pre-gapped). If that doesn't fix it try to borrow some coils before you fork out for new ones (Yellow jackets seem to be as good as the splitfires but cheaper).
As for the tuning get an Apexi SAFC (old cheap one will do) and if you can find one an SITC for the timing.
BTW if you do a search on coil packs you'll find lots of ideas for insulating them with tape or epoxy.
Well annually should be fine for plugs but sounds as though you may need coil.
SAFC is fo adjusting air/fuel ratios .. will overcome rich/retard (what you were referring to as fuel/boost cut.
Basic models are $100 -$200 there is a flash one with blue screen in the skyline parts for sale of this website
Google Apexi SAFC for more info
thanks heapswill ask my mate if he can get me one aswell as the coil's.....
are you born and breed in nz??
i am from kaitaia(though born in aussie so got the best of both worlds a convict and kiwi)
wife is from d'urville island.
the coil packs seem to bee the most common thing that stops boost is this right??
is this just because they are crap[ or is there a tech reason they cant handle boost??
will spend the rest of the night catchin up on SAFC
many thanx again
  • 5 months later...
I remember someone put some DIY intercooler cleaning but can't find it anywhere, think they had half and half mix of turpentine and metho from memory with a rinse of water at the end. I read on some other site people using vacuums to dry them out.
Yes its in the DIY sticky>intercoolers>>R34GTT i/c into stagea (and its kerosene and meths).
  • 11 months later...
Don't buy the rip off splitfires (yellow jackets/Just Jap/Red jackets etc) as they're a poor substitute. The voltage output is all over the show and the latency is very slow. They also don't seem to last to long either.
Origional or Splitfires.
Cheers
Justin
  • 1 month later...
  • 1 year later...
  • 4 weeks later...
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
