Well let me know what the problem is once you find out :rolleyes:
Can’t wait till the next track day, I have a month to fix the car now!
Ohh if you are upgrading your brakes and want to sell the Brembos let me know :cheers:
  • Replies 160
Posted Images
It went something like Aaron "Come on, you should be doing 1:02 easy around here"...so in what was a bit of a Roy/Sandown remark i think Aaron had to make sure he did a 1:02 :rolleyes:
Hopefully its just a gasket, but who knows...id hate to be changing a gasket though :cheers:
FERNI, if you are reading this...you on track with the new engine, or are you giving the car a rest for a while. Semis on you thing will mean you will be stepping up to the plate as well :D
Yes i'm reading this :( Engine is ready for it, pitty about the gearbox, but that should be sorted soon, nissan have offered me a refund on my gearbox so i'm hunting for a good 2nd hander, anyone know of any? Then its time for a new set of wheels and semis. Then i'll need a year or so to find my balls :P
Was there friday night, Aaron was stoked with his car, but only did 2 sessions so there may of even been a 61 in it with a bit more, who knows. Jacks 64 is awesome, he looked good out there, and at night, seeing those huge brakes glow down the end of the back straight was cool :D
Good stuff from everyone.
Now it seems this year is going to be a little more interesting. Last year Frank was too far ahead to try and catch and Chris was too far behind to push me.
Now my first thing will be to keep Jack behind me and Aaron seems like a good target to try and catch. Just sucks it's going to be Round 4 before I can get back out there.
Good stuff guys those are awesome times :D
Hats off to Jack and aaron for keeping those pesky rally things behind them :D
Also good to see Matt and Wayne up there in the RWD.....although is anyone running in std class this year??
Pics anyone??
I'm tempted to go back to std class! LOL. You boys are getting too quick for team stock turbs over here. Come mid year i'll be the only GTR running a std bottom end too.
Thats not a bad time Matt.
Well done Jack. It seems you've found your wang too. Keep it up. Looks like your going to be my benchmark now.
Cheatererer engine for cheater car?
Dont worry Chris, Team Std Turbs can still win the Motorkhana series :P
Now you know my frustration wathcning all the RB25 and RB26 powered guys walk away from me down the straights :)
There are some great pics in there Bec.....love glowing brake discs :P
And that pic of Jack (I assume it was - silver gtr) breathing fire was awesome.....hows the paint on the rear bar Jack??? :)
Were you there snapping shots as well Bec?
What happened to Clayton, did he have a bit of a lose. hope the car is ok.
Im just hoping my car is ready for Sandown, if it blows up anywhere i want it to be Sandown, close to home and the one track where i think i can learn it pretty quick...so after that i will worry about places like PI.
Plus the gravy train has run out for me , so dont think i can afford as many track days and mishaps as i have nedured the last 2 years :D
Thanks guys for the compliments, looks like it will be an exciting year of racing...
Snowy, you can chase Aaron, I'll chase you and Chris can chase me!!!!!
Chris, I'm sure if/when you ugrade your setup you'll be giving Snowy a run for his money too, give you big credit for the times you are putting out with only minor upgrades!!!
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
