got my 89' automatic r32 rb20det skyline dyno'd today
K&N pod filter(no heat shield)
r34 smic(1 of the pipes keeps popping off)
3" combined dump & front pipe and 3" hi flow cat from BATMBL
3 1/2" JASMA cat back from Japan.
$22 manual boost controller
r33 turbo 14psi(drops off to 11psi)
apexi safc tuned by HITMAN
was done in 4th gear
143.9rwkw
my first ever dyno with the cat back and pod filter i got 127rwkw(was done in 3rd gear)at Silverwater Automotive Services
both dyno sheets r displayed using my camera fone
the before(red line) on the HITMAN readout says 126rwkw
thats with everything minus the boost controller and safc.
Edited by RSTME
VH Commodore, R32 RB20DET
Std engine and turbo,
quiet 3" exhaust,
400x300 K&J cooler,
EMS computer
163rwkw @12 psi on JPC dyno
12.90 @ 111mph with stiff circuit spec suspension, old Advan tyres.
Fitted HKS T300 turbo and Tial 38mm gate, made huge difference. estimated 200? rwkw @ 18 psi. Will dyno soon.....
1993 RB20DET stock internals
3 Inch Turbo Back Exhaust
GTR Front mount
Stock Turbo
POD
Turbosmart Bleed valve
98 octane fuel
Power FC Tuned by Unigroup
166Rwkw 1 bar boost
Edited by Dave69001
R32 1993 GTS-4 Turbo
Standard RB20DET
Standard turbo
Standard computer
walbro 500hp fuel pump
3" turbo back
K + N Filter
stock boost when dyno'd and got 145rwkw on a 42 degree day
now i have installed front mount and upped the boost to 1 bar
I have a boost controller and I used it at three different levels
so at 14 PSI:
wheel crank
hp 265 335 @6250
tq 230 285 @5000-6000 Smile
__________________________
at 14.5 PSI:
wheel crank
hp 270 340 @6500
tq 240 298 @5000-5750
at 15 PSI:
wheel crank
hp 280 355 @6500 that's 208 RWkW
tq 260 315 @4750-5500 352 RWNm
Old ass blitz SBC boost controller
HKS GT2535 turbo
(N1?) GTR FMIC
Tomei Built RB20 2.2L with cams and all
GTR Injectors and Fuel Pump
3" catless RS*R exhaust
Z32 MAF
94 Canadian Octane gas
the tune is quite rich
You guys think it's the turbo/cams/injectors that are running out??
this turbo is rated 350HP which I'm at :S
Edited by klys
1986 200ZR NICS RB20DET
3" Turbo Back Zorst
Pod
R33 Turbo
SAFC2
Supra FMIC, 2" piping
Stock Fuel System (injectors, pump etc)
Turbotech Bleed Valve, set to 10PSI
144.1RWHP (108KW) sad, I know :no:
AFM hits 100% utilisation @ 5500RPM and everything goes to shit after that.
Edited by 200zRRR
Yo, my car is an A31 Cefiro with an R32 RB20det
Mods:
HKS Pod
3 inch exhaust
600x300x100 cooler
Custom inlet plenum (copy of jun surge tank)
Garret GT25 400hp turbo (0.64/0.70)
tuned length stainless high mount manifold
tial 38mm gate.
GTR Fuel pump
550cc S5 injectors
Sard Reg @ 40psi
RB20 AFM mounted in 4 inch intake pipe
Power FC
Just got back from tuner 2nite & the results were: 258kw@ 18psi (dynapack chassis dyno) supposedly it works out to 406hp @ the flywheel.
Lastest tune and mods
1992 R32 gtst
rb20det stock bottom end (65000klms)
hks cast exhaust manifold
hks 35mm external wastegate
hks adjustable cam gears
hks 264 cams 9mm lift
600x300x76 hybrid intercooler
malpassi fuel reg
sard 550cc injectors
ported and polished head
catco high flow cat
custom 3' dump
hks 3.5 exhaust
garrett GT3040R turbo
Haltech ecu e11v2
Made 281.8 rwkw @22psi
R32 gtr fuel pump
cheers Peter
Edited by legend01
hi, unfortunaletly i don't have an electronic copy of my dyno to post up, but here are my mods and result.
1990 R32
Standard rb20 internals
rb25 series one turbo on stock manifold (using rb20 wastegate actuator)
quiet 3 inch zaust, custom dumppipe
k&n pod in cold air box
stock AFM
Retuned ECU
14.1psi - via an E-Boost
300x600x76 bar and plate (no brand) intercooler
custom intake manifold (front facing throttlebody)
460cc rx7 injectors (non turbo)
proSport fuel regulator
standard recirc BOV
192.6 Kw's at rear wheels on torque performance dyno (i think temperature was 23degrees.)
i just picked up my line, so thought i'd put up the details (not much to brag about though) ;-)
1993 R32 GTS-T (5 spd)
RB20DET (wrecker engine - standard internals)
stock RB20DET turbocharger & dump pipe (stock boost)
stock exhaust and inlet manifolds
stock AFM
stock injectors, etc
stock intercooler & BOV
3.5" aftermarket cat-back exhaust
K&N pod filter
Apexi PFC - conservative tune
132 rwkw @ stock boost
p.s. i have bits sitting at home waiting to go on to get this thing boogying
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
