Internally stock RB20DET in S13 Silvia.
MODS:
- KKR430
-Apexi AVC-R
-RB26 Apexi Power FC
-Full 3 inch custom exhaust system with 3” high flow cat
-Front mount intercooler with custom piping
-Custom solid intake pipe with pod mounted behind headlight.
FUEL SYSTEM:
-400cc Injectors
-Bosch 040 Fuel pump
-Sard Fuel Pressure Reg with Fuel Pressure Gauge
1.4 bar saw 301.7hp at the wheel on a hot day here in QLD.
Mtq rb25 hiflow@18psi
hybrid fmic
gtr injectors with resistor
gtr fuel pump
turbo back 3" exhuast straight thru
pod
turbotech style manual controller
safc2
All built in my garage by me.. stoked!
305.5 rwhp or 230 rwkw
img_3120728_0001__2_.pdf
Edited by RaZ_TuRbO
rb20det 2.2litre
-Os Giken Cam Pullys
-Tomei PROCAM Camshafts 256degree 8.5mm
-Metal Head Gasket
-Nismo 600cc Injectors
-Tomei 2.2 Forged Pistons
-12 Port Head
-Port and Polish
-Bosch 044 Fuel pump
-3 1/2" Rsr Catback Exaust to 3" Downpipe
-Apexi Power FC
-Apexi AX53b70 -P25
-Hybrid Frontmount 600x300x100
302@rears 18psi awsome power band for rb20
http://img265.imageshack.us/my.php?image=dynojw2.jpg
Had another retune yesterday to iron out some flat spots...mods have not changed...
1989 RB20DET R32
3" Turboback Exhaust with 3" Metalcat
Hybrid FMIC
Bosch 040
GTR Injectors
Z32 afm
Just Jap coilpacks
Turbotech Bleeder
Aerospeed cam gears
HKS 2535
DR DRIFT Remap
Power is up to 237rwkw @ 19psi with AFRs sitting safely at 12:1...which is a decent improvement from my last tune...curve is not as smooth as before probably due to coils/plugs/slight boost fluctuations...but it'll do... :D
RB20 - Maybe RB24 (Not Confirmed)
CAMS - 272/272 (Not Confirmed)
TURBO - HKS TO4ZR
ECU - Remapped Factory ECU (Not by me unfortunately)
POWER - 367rwkw
We had to limit the boost to 23 psi as the std ignition system was breaking down and loosing spark. The 367rwkw was run with slight misfire, confident of more with better spark...
Anyway, pictures tell a thousand words...
RB20DET stock
HD Industries ex manifold , Tial 38mm waste gate , bosch 044 fuel pump , bosch 363 injectors ,
Motec M800 , Custom plenum , 70mm throtle body , 600 x 300 x 105 FMIC
I have just fitted a GT35/40R with a .82 ex
262 rwkw at 16lb boost
STU
1991 R32 GTSt
Stock Engine (RB20DET)
Stock Turbo
Stock Intercooler
Stock Exhaust, cat, dump, front pipe, manifold
Stock Computer, fuel pump, injectors, reg
Stock airbox and filter
Internal wastegate running at 12psi for some reason
140rwkw, 260Nm
1990 r32 gts4,
Stock internals
Tomei head gasket
Nismo 555cc injectors @ 45% duty
Z32 afm
GTR Power fc
Bosch 023 fuel pump
Hypergear TR43 turbo
Turbotech boost controller.
Hybrid front mount
Apexi cat back
Apexi pod
Xforce cat
195rwkw @ 15psi just at high rpm
Looking for 230 with a EBC and 18psi
Edited by dmac_25
Std capacity R32 RB20det
Std original pistons
Std rods and crankshaft
New rings and bearings
Metal Head gasket
Std RB20det camshafts
Ebay adjustable cam pulleys
Std head
Shimmed Std Valve Springs for extra seat pressure
GTR inlet plenum dodgily welded onto rb20det inlet runners (none of the runners line up, it's awesome)
850cc injectors
Fuel pressure regulator
Ebay 100mm throttle body
Splitfire coilpacks
Ebay Stainless highmount manifold
Ebay External wastegate
Monza 600x300x76 fmic
T04Z turbo
Remapped Std ECU
370rwkw
Limited by cams, traction and stupid tall diff ratio. Hits dyno maxspeed, power still climbing.
There is a thread about it here in the SA local section.
Edited by TSL
  • 3 weeks later...
Stock RB20 with standard turbo
12 psi (but drops to 9)
3" exhaust with dump pipe... VERY quiet system
BKR7E's
Walbro pump
Front mount
Dr Drift ECU remap
Pod Filter
148.9kw @ the wheels (made @ 9psi)
Edited by Hibino
  • 1 month later...
1990 R32 skyline GTS-t
internally stock RB20DET
555cc nismo injectors
Z32 AFM
450hp T3 disco potato
split dump pipe from just jap
hi flow cat
3inch Drift cat back exhaust with 4.5inch cannon
Greddy 600x300x76 FMI
splitfire coilpacks
bosch 044 fuel pump
K&N pod filter
remapped ECU by Dr Drift
223rwKw's @ 18psi
Edited by brouny
internally standard RB20DET
low mount TR43 turbo with 15PSI actuator
standard injectors
3" single chamber dump and front pipe
3" hollow catalytic converter
3" nismo stainless steel cat back exhaust with magnaflow rear muffler
600x300x75mm hybrid front mount intercooler
no pod/airbox
3" alloy intake pipe
3" CAI feed
GTR fuel pump
produced 210.7kw at the wheels with 10.5 AFR
Edited by dmr
1989 r32 gts4
t3/t4 hybrid turbo
emange computer
nismo highmount manifold
hks 50mm wastegate
splitfire coilpacks
3inch apexi exhaust high flow cat
blitz frontmount cooler
heavy dity valves and springs
550cc injectors
bosch 044 fuel pump x1 plus standard pump into surge tank
boost controller set on 12psi low boost has been 22 psi but bad boost spike
spool adjustable cams gears
k/n pod filter
made 220rwkw on 12psi will make well over 240kw on high boost without spike. very laggy set up full boost hits at 4700
91 R32 GTSt
Everything standard except:
Trust TD05-16G (no boost controller, peaking at 12psi then dropping to 9)
Trust cast dump pipe (came with turbo kit)
Blitz Front mount intercooler
Trust Power extreme exhaust (with 1" silencer plug in rear muffler, standard cat still)
This car has not been tuned with the standard computer back in (had to take out eManage Ultimate when i got done by EPA a while ago, along with all other mods :D )!
It was put on the dyno to check out AFR's...
148.6rwkw @ approx 5500rpm
3800N (not on this chart)
Edited by eSKiMo
i have a 1993 R32 GTS-T 170,000kmz
K&N Pod air filter
Cold air intake
platnuim spark plugs
300x600 front mount
2.5" turbo back exhaust
Walbro intank fuel pump
SAAD fuel reg
Garrett GT2871R turbo
Greddy electronic boost controller @15psi
made 186.4rwkw on 19" wheelz
goal is to hit 250
  • 3 weeks later...
1989 R32 GTS-t
- Internally std RB20DET (127 000kms)
- K&N pod fillter
- 3" exhaust turbo back (no cat)
- Plazmaman Plenum
- Cooling Pro FMIC 600x300x76
- GCG R33 Highflow turbo
- Std Exhaust Manifold
- Z32 AFM
- Splitfire coils
- 440cc GTR injectors
- Bosch 040 fuel pump
- Dr Drift Remap ECU
- 98ron BP Fuel
232rwkw's (311.12hp) @ 17psi boost.
Big thanks goes to Dr Drift for all his hard work
cheers
bill
i got......................
1989 r32 gtst
stock rb20det engine
stock plenum
700cc sard injectors
rb25 turbo
full custom 3" exhaust (made by AAA exhaust in mackay)
cooling pro front mount 600x300x75
torbsmart boost T (boost is set to 13 but tapers off to 11 after 4000rpm)
gtr power fc (tuned)
bosch 040 intank fuel pump
drift pod filter
98 fuel
everything else standard
made 165rwkw (222.1hp@5700rpm) and 458.0 N.M of torque
will try to get dyno sheet up
this is my boyfriends car
Edited by NeboRdChick
1992 R32 GTS-T
102 5XX k's on the clock
The following modifications:
- POD Filter
- 3" turbo back exhaust (Just jap dump, X-Force Highflow, Kakimoto muffler)
- FMIC
- Greddy Profec B Spec II Electronic Boost Controller
- HKS SSQ BOV
- 440cc GTR Injectors
- GTR Fuel Pump
- RB25 Turbo from an R34 (Nylon Compresor Wheel)
- Stock ECU with Nistune ROM remapped by Allstar Tuning in W.A
- Stock AFM
- Stock Plenum
- Stock Coilpacks
- Sparkies gapped to 0.8
- Running 98 RON fuel
Made 195 kw or ~261 hp at the wheels at slightely less than 1 bar. ;)
Very happy with those results.
Edited by Douse
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
