Just read in the "Smokin" column on page 39 of the latest Wheels mag, and it writes that when the R32 GTR first lobbed into Australia the great man himself Kerry Packer(RIP), bought one and then 2 more (which model not known), and was regularly seen driving to work in one.
From Wheels:
"That day was the beginning of a long-lived affair. Kerry Packer eventually bought three GT-Rs. Through the 90's I would sometimes spot him in one, driving himself to the office. It says something about the man that he chose a relatively affordable Nissan, even though he could have afforded anything he desired."
Who would of known that Kerry Packer was a great fan of the GTR...just puts a smile on my face and enforces my love for the red emblem. :(
https://www.sau.com.au/forums/topic/103213-kery-packerwell-that-is-a-surprise/
From Wheels:
I seem to remember he entered one of them in the Targa Tassie events in 1993 or there abouts. Can't remember who drove it other than the fact that kevin Bartlett had some involvement...
Kevin Bartlet drove Packers R32 in Targa in 93 and 94 from memory. Packer was to go nav but pulled out last minute.
A mate of mine bought what he understands is his Packers former R34 a while ago.
Well, the man obviously had good taste.
Yes he sure does B) , especially considering that the man could have afforded "any" other exotic sport car in the world.
I don't think I know of any other high profile figure to have a interest in GTR's let alone the "very" high profile Mr Packer.
Don't even think others would even consider it in any instance, and most likely dismiss it with a snoobish attitude, as it is not European.
Given that Mr Packer loved it, say's a lot about the man, and volumes for the car :D
the gtr r32 he brought which 'first lobbed' into australia probably cost  150 grand in todays terms. hardly sounds 'relatively affordable ' to me.
They where actually $110,000 fromt the Nissan dealer at the time, but I believe they dropped in the range of $90-80k as sales where few and slow.
He has acertain GTR which has a lot of work done to it, built by the very same people that had some success racing them.;)
Black but looks std, but pretty close to a Grp A car.:rofl:
Would of been quite a sight to have seen him in this car :P
He has acertain GTR which has a lot of work done to it, built by the very same people that had some success racing them.:rolleyes:
Black but looks std, but pretty close to a Grp A car.:D
So it would be a VERY fast car then? Or just really quite fast?
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
