Well..... I specifically asked for a clutch that could handle 600HP with odd track days & drag-strip work (+ a specific reference to DirtGarage's clutch) .....unfortunately in my case, it was obviously not a 600HP rated unit.
You ran a clutch rated to 600hp... with 600hp (or a tad more)...
In all honesty, what did you expect?
Its like getting a tyre rated to 300km/h, and doing 300km/h just to see if it will blow out.
A smart man would get a 330km/h tyre or a 700hp clutch IMO to give you headroom rather than tempt the devil ;)
A smart man would get a 330km/h tyre or a 700hp clutch IMO to give you headroom rather than tempt the devil :)
I went solely on Jim's advice, he reckoned the twin plates were a waste of $$ as his super-single plate would be more than ample...........so "in all honesty" I expected the clutch to work, but given you're all seeing and all knowing you obviously knew what I discussed with Jim ;) PS my mph at the strip when the clutches actually failed indicated the engine was well under 600HP (120-122mph).
  • 3 weeks later...
I hear a few people commenting on them being very hard on take up, does everybody experience this or is it just Jim's "full monty" that drives like this
I have the decision on what to use in the 200SX, the box blew, so was thinking of using one of Jim's clutches..... i have just been a bit concerned on the clamping force, 4000lbs in this case, and the effects this may have on thrust on the RB's crank.... its a hell of a lot of clamp
Can anyone comment on how nice the pedal is on one of Jim's clutches that has above 3500lbs clamp??? i would have thought you would need legs like Arnold to use it
  • 3 weeks later...
I think mine has 4400 pounds from memory. I remember Jim saying it was the most he ever got out of a standard GTR clutch. I wouldn't say you need legs like Arnie but the friction point is very small.
Remind me some time Brad and you can test it out.
I'm only aiming for around 220kw. Should I get the Jim Berry "mini-monty" or will the Exedy HD Organic clutch be sufficient? If I get a clutch from Jim will I have to purchase throw out bearing etc separately?
How about this as an alternative?
Exedy "Sports Single" Sports Organic - NSK-7056SO (RB25DET): $573.65
Edited by Simmo1985
Spoke with Jim Berry today. He's making me up a clutch, it's a level below the "mini-monty". It's got the "full monty" pressure plate with an organic face or something. It was all a bit double dutch to me but I'm sure I'll be satisfied with choosing Jim Berry over Exedy. Just need to book it in to get fitted somewhere now.
hmmm,
my JB 'full monty' slipped on the weekend when I did a cupple of 6k+ launches in my R32 GTR
its a carbonic clutch plate with 4000lb pressure plate and has done 3000k's
first launch it fully slipped and did not properly hook up,
second run it slipped and eventually hooked up. After the launch I went to drive off normally and the clutch wouldn't engage and just slipped and shuddered.
I got the car moving and it seemed to right itself (drives fine now, but I havnt attempted another launch)
I'm a little dissapointed as my 'stock' GTR makes only 230AWK and when I did the launches I was not running my usual 1bar, I was only using .7bar.
It also makes a bit of a clicking sound when depressing the clutch.
The unit was installed by my tuner following Jim's strict instalation instructions.
fitted the unit set me back close to $2k and I am not a happy camper :(
Edited by Betz
My new JB clutch is in. Working well so far, it's just a Heavy Duty organic style. Not full monty. It seems to make a bit of a clicking sound when releasing the clutch, but the stock one did that too, so hopefully it's normal.
Sucks to hear about your clutch slipping. Nothing worse than wasting ridiculous amounts of $$$ on something that doesn't do what you want it to!
On a side note, when I went to pick up my clutch I paid by EFTPOS, it wasn't til I got back to work that I checked my bank account and noticed no money had left the account.. checked the receipt, my card was denied for some reason. If I was a scumbag I coulda got a free clutch haha, rang Jim up and direct deposited the cash straight away though.
hmmm,
how do u drive the car day to day? as in do u slip the clutch?
I 'slip' the clutch as little as practical to get the car moving smoothly.
the take up has always been very fast,
I usually give 1500rpm and come off the clutch quickly and can feel the clutch hook up smoothly.
changing gear I can get smooth changes without needing to induce slip and its only when driven hard that gear changes are a bit violent.
my pedal hieght is a little higher than I would like, but it has always been like that even when the clutch was first installed.
the clicking sound when depressing the clutch is like the diaphram has a cupple of broken fingers.
the clutch also squeals when its cold and is engaging, this goes away after a few k's of driving and indicates to me the clutch has been run in and the high points knocked off.
if its dead then its pretty piss poor value 3000k's for a $1500 clutch :(
  • 3 weeks later...
  • 3 weeks later...
Need to do the clutch in my R33 gtr soon.
Anyone had any experience with this Xtreme clutch?
It's 1260kg clamp load (approx 50% over standard), and a dampened hub with cushioned ceramic facings.
At the moment I might be making around 230kw atw, but need it to handle 330kw atw.
Ballpark price i've seen at the moment is around $1100 for the kit.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
