Ive had a Jim Berry "race clutch" in my 33 for the last 18 months and it has never slipped and was running 300rwkw. I know have closer to 400kw and even a 6500 launch and slicks still didnt slip. They are awesome.
stock drive shaft, gearbox an diff?
if so how they holding up with the high rev launchs??
an what times you been running? ?
  • 3 weeks later...
speaking of nismo super copper mix twin plates
RHD Japan is having a sale for a lot of stuff including this clutch, usually fetches 2.5k easily. Managed to grab one for 2k delivered
be quick, only on for a few more days
http://www.rhdjapan.com/nismo-super-coppermix-twin-plate-clutch-r34-bnr32-bcnr33-15111
  • 1 month later...
Just fitted an NPC 10", organic, heavy duty clutch (good for up to 300rwkw) and it is a thing of beauty.
It has a very nice progressive feel to it that the stock clutch didn't (it was likely on it's last legs when replaced)
If the pedal is heavier than stock then not by any amount that I can notice (see above).
The best thing is that it was only half the price of a JB clutch!
In fact I got a steel billet lightened flywheel (also very nice) and the clutch from NPC (plus half the labour costs to install it) for less than the cost of a JB clutch (no exchange required).
I'm sure Jims clutches are good but fark me they are expensive! (way too much $$ for me to justify the spend)
I am only running 244rwkw so don't need the full monty even though that's what I was being "up-sold" to...
Edited by Checkbuzz
Single plate is good for stock, don't get a twin plate exedy as they are terrible to drive
Marko, just wondering what makes them terrible to drive as i was recomended to get one by a workshop?
Car will be back on the road tomorrow with a custom JB clutch - built out of my old extreme HD clutch that was apparently using the highest rated Nismo pressure plate and diaphragm - Looking forward to seeing the difference as I wasn't terribly keen on the clutch as it came from extreme, and it only lasted a year (with no drags being in Adelaide and barely a handful of mild launches).
Will report back after I've driven it over the weekend.
I'm sure Jims clutches are good but fark me they are expensive! (way too much $ for me to justify the spend)
+1 for me too. Very helpful, and had the clutch and flywheel delivered in 3 days.
Update: This may well be the first bad thing said about JB on here (sorry JB!) - got the clutch back from QLD, put the car back together and we couldn't get it into gear at all. Turns out JB made a mistake and somehow sent the wrong pressure plate. Oops!
Waiting for the correct one now...
  • 1 month later...
hey guys just recently fitted a twin plate nismo coppermix in an r32 gtr. Drives really nice, no shudder and pedal felt lighter than stock. One thing though im not sure if other nismo users experience the same thing but the pedal sits really high
hi guys
I've always heard jb have a good rep but have had 2 mates with problems from jim, the first was a stock rx-7 fd and got the clutch back and terrible shuddered and was just a light switch, and the second was a supra and couldn't get it into gear both where traced back to mistakes by jim.
Just installed a new NPC 10" heavy duty organic clutch and new flywheel. OMG, the car drives so much better now. Can highly recommend this NPC clutch. Rated to 300rwkw +. Handles the power and is so easy to drive.
You guys with mostly standard cars could also have a look at Gripforce/F1 racing clutches too, i have one in my 300ZX and they are great. They are cheap and pretty big over on the 300ZX forums, my 6 button clutch was $750 installed and has 250% clampforce increase over stock. I know that R33 GTSt and 300ZX NA clutches are interchangeable, 300ZXTT however are a fair bit bigger. Just throwing it out there, you guys don't need to spend heaps on clutches if you aren't making huge power.
Edited by Super Drager
  • 1 month later...
well my 3 month old 10' carbonic NPC clutch welding to my flywheel,
clutch sliped on a launch car is making 340rwkw with street tyres.. not sure how but we'll see what thet say i have sent it back to them to check out.
so got the call off NPC on Wednesday.
they seemed very helpful, they have rebuilt the clutch plate and are sending it back for me today. after sales service seems great.
will report back once the clutch is in and all good.
did they give any explanation,? or use a different material this time ? I used to do it heaps with my old JB single, got the point where every time I launched even with no riding the clutch it would weld :domokun:
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
