LOL. I have no idea how to react to this...
You can react by crapping your pants!
I can practically SMELL Snowplow's money. Team Gayside best keep their cocks in check!
Troy - crack me a tinny and fire up Gran Turismo. I feel like some practice...
  • Replies 193
Posted Images
Keep an eye on the Evo driven by matt cherry and kim ledger, its one seriously fast and well sorted car, makes a dab under 400 at the treads on 98, 8 pot bembo's up front and they can both fairly peddle, around the track it'll be brutally quick, notarus and authur will probably flog everyone on the motorkhana stuff, damn those guys can hook a car around a khana
Meh, all those hacks that take the event way too serious :D
The real battle will be between the SAU-VIC Pres and his pretty boy team mate in that Brock Blue R34 and Team Max AMEX in the completely std R32 GTSt... Handicapping means we only need to win one of 48 events to take the money.
The arrogance of these guys to think they will beat us in every single event. :D Just because they got a fancy car and can drive...and me and Jamezilla dont/cant...we are Australian, and in the tradition of Steven Bradbury surely they have to fark up one event and hand us the win.
If you cant win just hang around and hope they fark up and pick up the pieces :P
Pfft - there nothing standard about your R32 Bris. But still thats not going to stop the fact that you will get beaten in every single event.
Team Skills will beat Team Dills every time. :woot:
September seems like such a long time away!
Team Skills will beat Team Dills every time. :P
Just be very, very, very careful Snowplough...that bottle of water you pick up off your seat could be loaded with laxatives. That drum of ELF fuel you use to fill up your car full of sugar. Your radiator full of the piss from village drunks at Taco Bills...things you have no chance of knowing about ... i would be hiring full time security for that car of yours, otherwise you could find you have some reliability problems :D
...and everything on my car is std, i have to return ot to stock for rego and cant be stuffed putting all the gear back on it...dont need it to beat you hillbillies
Just be very, very, very careful Snowplough...that bottle of water you pick up off your seat could be loaded with laxatives. That drum of ELF fuel you use to fill up your car full of sugar. Your radiator full of the piss from village drunks at Taco Bills...things you have no chance of knowing about ... i would be hiring full time security for that car of yours, otherwise you could find you have some reliability problems :)
Hey, Aren't you guys both navigators? Who's gonna drive?
The GPS has no hands!
Alright boys - it seems there are some "Official" Dutton Rally forums to be found on the Autosports forums.
http://www.autosports.com.au/forum/forumdisplay.php?f=60
They are all too serious. I've started up a thread in the Victoria section. We need to make a mocery. :P
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
