In R34 road car with full interior etc
R.I.P.S RB30, forged internals
R.I.P.S RB26 head, tomei 290 cams
GT42 turbo
900kw (1200hp) at engine, best measured at 4 wheels on rolling road with wheelspin 720awkw (960awhp)
First time I'd ever driven the car was its first ever pass at the drags:
Should run low 9s with some practice and she weighs 1740kg.
Rob
Update on this car.
Changed to Q16, 1051whp @ 1.9 bar, no NOS.
Ran 9.4 @ 155mph with a 1.5 60ft on a very slippery track TOTB8 in the UK still at 1740kg.
Possibly the quickest/fastest full weight + street R34 in the world??
Rob
  • Like 1
RIPS RB30/26 streetable engine
Stock RIPS prepped 2wd block, no filler or braces, fully water cooled.
Stock RIPS prepped crank
RIPS 2wd wet sump, tomei oil pump
RIPS RB26 head, brand new with tomei parts
RIPS inlet plenim with 90mm TB
RIPS custom exhaust manifold
GT45 turbo
Twin turbosmart 50mm progates
75hp NOS kit
1100whp @ 9000rpm, 2 bar on C16, 8.05 @ 172.3mph
Rob
Update on this car:
1200+whp, C16, 7.86 @ 177.4mph
Worlds quickest and fastest 240z and RB30.
Edited by R.I.P.S NZ
  • 4 weeks later...
Hey guys
R.I.P.S 4wd billit main cap block rb30
argo rods
stock crank
je pistons
rb26 head work done by Rams
twin hks 3037s turbos
street tune 98 octane 24psi car made 553.5kw at all 4 wheels
Update
673.4kw at all four on 30psi and roo16 fuel
NO GAS
  • Like 1
Here's mine
Autronic SM4
R32 RB25DE head
HKS 264x8.5mm cams
Cam gears
Denso 660cc injectors
40thou oversize CP pistons
Argo I-beam rods
ACL Race series bearings
ARP headbolts
ACL Metal Headgasket
GTR oil pump
Crank collar
Fully balanced
Trust T67-25G high mount kit
Bosch 044
Stock plenum, no headwork
Edited by salad
Here's Mine
RB30DET
RB25DE head from R33NA with VCT disabled (completly stock)
RB30E bottom end rebuilt with new rings and bearings 35000 k's ago
stock cams
stock inlet & exhaust manifold
Holset HX35W
40mm external gate
740cc injectors
Z32
3" turboback
Stock R32 ecu remapped by me
enough torque to break lots of things...
boost tapering from 19 down to 16psi (got to get the control issues sorted out)
running bugger all timing and 11:1 AFR's to keep the block in 1 piece
Also was done with a set of semi slicks! good on the street but no good for dyno figures...
The dreadded stock manifold brick wall is very close. Once the boost is stable at 19psi it will do 300rwkw easily.
it kept making power to redline LOL!!!
  • 4 weeks later...
R33 series 1 gtst
rb30 bottom end with:
ACL Forged .20 oversize pistons
standard rods with arp rodbolts
rb30 crank with oil pump collar.
ACL race series bearings.
rb25det neo head with:
modified water gallery tig welded and machined.
standard valves,
standard springs
tomei rb26 inlet cam
rb26 exhaust cam
adjustable cam gears(haven't played with these yet)
rb26 covers
custom 4 inch air intake/AFM housing with standard rb25det MAF sensor.
garrett gt3076 .82 turbo internal wastegate with upgraded actuator
standard bov recirculated
hdi frontmount with custom 2.5/3" piping
chinagreddy intake plenum with q45 throttle
custom 3.5" dump with 3.5" hitech stanless steel cat, exhaust splits into 2 x 2.5" shortly after cat through hitech twin 2.5" centre muffler then two hitech 2.5"/5" o/d cannons
sard 550cc sidefeed injectors
standard fuel pressure reg
bosch 029 in tank pump with 8gauge wiring and 30 amp upgraded relay and fuse, direct earth.
r32 rb26dett computer with nistune and some internal modification for AFM and O2 inputs.
justjap coils
r32 gtr diff,driveshafts and rear hubs
daily driver, roadworthy and registered with all current modifications.I'm sure there's stuff i've forgotten but that's most of it.
runs about 16 psi with just actuator preload, no boost controller.
399.7hp atw.(could not find the final dyno run printout but have one from when it was getting tuned. close enough.)
post-36856-1256526409_thumb.jpgpost-36856-1256526327_thumb.jpgpost-12805-1125046399.jpg
  • 4 weeks later...
RB25/30 Series 1 R33
Tomei Poncams
550 top feed injectors
Plasmaman plenum 72mm throttle body
Forged internals
Haltech Sport 2000 ECU
Single 044
GT3076R low mount
310rwkw
990 Nm
Now have 337 kw and 1120 Nm of tractive torque all thanks to large can 18 psi actuator
Full boost 700 rpm earlier than before.
RB25/30
Stock Head
Built bottom end
GT3082R, EMS, 550cc, 6Boost etc.
246.3rwhp @ 6psi. Was the second run just starting the full tune and sump split. Made a shit load of torque and looks promising. Will get graph up tonight.
Hell nice, a similar setup to what im building.
Could you tell me what exhaust housing size you are using and how off boost drivability is with the 3076 combo? I dont want my setup to end up too trigger happy :P
Update:
Rb25/30
375rwhp @ 18psi. Will be going back on the dyno this week as there were some cooling issues on the dyno. But I wouldnt expect it to pick up much more than 10 - 15rwhp. Can someone possibly explain why my figure appears relatively low compared to most others on here.
RB30 with series 2 turbo 25 head
GT3082 - .82r
EMS Stinger
550cc Inj.
GReddy plenum 80mm TB
6 boost
3" exhaust
Built botto end with 8.9:1 comp
I am guessing my read out appears low because of the auto. Its a KEAS built auto, fully manualised box with 4200rpm stall.
I will try upload a dyno sheet tonight.
  • 4 weeks later...
Posting for a friend.
Built 25/30
3x 044s
1200cc injectors
Greddy plenum
Infinity throttle body
Turbonetics GTK 1000 on ETM manifold.
E85 Fuel
29psi (with leak)
692rwhp (514rwkw)
Engine
26/30
PowerFC
044 intank pump
RB26 head, light port, decked, CC'd chambers, performance springs, standard valves, stem seals, seat pressures etc etc
Tomei 260, 9.1 cams
Adjustable gears
OEM fuel rail
Siemens 870cc injetors, 2 pintle design (currently 700'cc from previous engine)
Turbosmart FPR- (have SARD not fitted)
Cometic 1.2mm HG
86mm ACL pistons 20though over 9.0:1 comp ratio
Spool rods
GTR plenum and throttles.
Head Restrictors and enlargend oil returns
Block x-rayed, decked and internally painted, welsh plugs etc
ARP head bolts
ACL bearings
Crank polished and grub screwed
Ross balancer
N1 oil & water pumps
Jun crank collar cryo treated
Enlarged sump
Splitfire coils
Garrett 2560-5 turbo's
Xforce dumps
Tuned length front pipes, 3inch to cat, 3.5 from cat
Retarded timing 6psi ~200hp. No dyno graph, no point yet. Will update once engine has some km's on it.:D
UPDATE
I have since re tuned my car and it is now making 437RWHP at 19psi.
specs as follows
RB30DET - RB25 NA head, stock cams
RB30E bottom end rebuilt to standard specs.
modified standard manifold with external 40mm gate
HX35 with 10cm^ rear housing
740cc hiflowed standard injectors
Z32 AFM
3" exhaustFMIC
splitfire coilpacks
No VCT
boost now a dead flat line @19psi.
Remapped stock R32 ecu. idles like factory and still returns close to 400km's to a tank!
standard everything else.
full boost at 3400rpm, power keeps climbing to redline, torque curve is nearly flat once it reaches full boost
  • 2 months later...
After 30 mins of messing around with the new ecu, this setup exactly the same as below, results;
401 kw atw, 24 psi (will go to 30psi), 6300rpm only (out of 9500rpm), maxed out injectors. Too much crank signal noise to continue, external crank trigger needed before going back to the dyno.
Torque is massive as you'd expect, here's a quick vid http://www.youtube.com/watch?v=QCkm6174AbA
^^^Thats the old motor and setup.
Here's the current setup;
-Stock head ports
-Tomei cams 270 IN and EX, 10.25mm lift IN and EX
-Tomei buckets
-Tomei springs
-Tomei head restrictor
-Adj cam gears (still set to zero though :) )
-Mahle 87mm pistons
-Spool rods
-ACL Race bearings
-Fully prepped crank inc collar
-JUN oil pump
-N1 water pump
-Fully prepped block (no hardbloc used)
-BCNR33 N1/24U balancer
-Custom 8.5plus litre oil sump (baffles, gates etc)
-Alloy radiator
-Header tank
-Splitfires
-Custom fuel rail
-1000cc injectors
-3 x Bosch 044's and custom lines, speedflow fittings, huge undercar surge tank etc
-Nismo adjustable FPR
-ARC airbox
-ARC intercooler, Hard pipe kit
-HKS thermostat controlled oil cooler and relocator
-HKS GTRS Turbo kit (ceramic coated)
-Stock GTR manifolds (ceramic coated)
-Tomei dumps (ceramic coated)
-HKS front pipes (ceramic coated)
-Oil return from head
-All balanced of course!
Plus the rest of the usual gear (R3C Osgiken clutch, ProfecB specII EBC etc)
Had dramas with a recently purchased Autronic so tuned on old ECU. Limited to 18psi due to map resolution, tune took all of 45minutes in total. Will retune as soon as the Autronic is fixed and increase boost and ignition, also cams will be dialled in.
This graph is torque vs power; Needs more boost, but is already MUCH more usable then the old setup
New motor and turbo setup is already coming together, wont be long now until its in the car and tuned :D
26/30
PowerFC
044 intank pump
Tomei 260, 9.1 cams
Adjustable gears
OEM fuel rail
Siemens 870cc injectors
Cometic 1.2mm HG
Spool rods
ARP head bolts
ACL bearings
Ross balancer
N1 oil & standard water pump
Enlarged sump
Splitfire coils
Xforce dumps
Assembled with loving care!
6psi 260ish hp
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
