Some facts on KKR, to help reduce some of the confusion.
Yes they are a plain bearing or 'bush' type turbo. A lot of people put too much weight on this specification, when really the way the turbo performs on the engine is what matters and there are clearly plenty of users who are happy with the results.
They come with a 6-month unlimited replacement warranty, which is the best warranty offered by any turbo manufacturer to our knowledge.
They are not the same as the many 'ebay turbos' that have been mentioned. These are manufactured by a company which builds turbos for various European OEM customers, using all German machines.
They are not a direct bolt-on for any particular engine, but the work required to fit a KKR430 or KKR480 to an RB20 or RB25 is not very complicated and the whole job can be done in half a day. It is true that with a dump pipe and installation the KKR480 will cost $1500-1600, but compare this to most other options and you will find it is still extremely cheap. Remember fitting any turbo, including a 'bolt-on kit' will cost a few hundred in labour.
As for power output, we have seen many RB25s making 240-260kW at the wheels with a KKR480 and 16-18psi boost. We have also seen the odd unusual example making close to 300kW, but given the manufacturer rating of 480hp, mid-200s are a realistic expectation.
We have yet to see any KKR430 turbos used in a high boost application, but with 12-14psi we have seen 180-215kW at the wheels on RB20 and RB25 applications. The smaller exhaust housing and turbine make it less suitable for high-boost applications, but it is very efficient at moderate boost levels.
On an RB25 a KKR480 will deliver full boost at around 4000-4500rpm, depending on tuning, cam timing etc. A KKR430 will deliver full boost by 3500rpm, but both turbos begin to produce boost from much lower rpm.
Ultimately the results will vary a lot depending on tuning and the other parts fitted to the car, but keeping in mind the price, the KKR turbos are hard to beat on a dollar-per-horsepower ratio.
Anyone wanting more information should refer to www.otomoto.com.au or email [email protected]
  • Replies 117
Judging by that dyno graph, it shows that positive boost (around 3psi) is made ~3300rpm and full boost is achieved at ~5000 rpm? Is it just me or does that seem a little late?
Ben, on your own website
Tested by Croydon Racing Developments on an RB25DET Neo engine, it produced 242kW at the wheels at 18psi.
297rwkw is 55rwkw more, with 3psi less boost.
On a motor that has a 1.8mm head gasket, i find that also to be quite interesting.
Upto 20rwkw variance i could believe... 55rwkw variance my mind tells me isnt correct.
Also, would you be able to shed some light as to how a stock RB25... which means 370cc injectors to the best of my knowledge... can make 297rwkw?
There is no mention of a massive fuel rail pressure increase that im aware of, being its a stock motor.
Im very interested to know the above as are many others im sure
Best to call Jake's Performance for info on the tuning of this particular car. It did have a huge fuel pressure increase as far as we know. As for the later spooling, again this relates to tuning, cam timing, compression ratio etc.
Abit off topic: my r33 made 290rwkw on standard injectors. this was with massive fuel pressure increase and 044 pump. tuned by matty spry in se qld. most se qld people will know who he is. My comment is to support the fact that 360+rwhp can be made on stock injectors but they will be at there limits. Several qld cars have made over 400rwhp on stock injectors and ran into the mid 120mph range down the 1/4. I would say they should take that car down the track to show its potentail.
have a quick looksy at
http://www.skylinesaustralia.com/forums/in...e=post&id=25136
if you wanna see how this turbo combo compares against some other rb25 turbo setup.s
With a lower BP reading is shows a higher RWKW figure as its in shootout mode. My friend has a dyno shop and his dyno read around 98BP when it was 101BP. I kept on getting high figures approx 10% higher. Went back to the shop when it was fixed and he showed me how it all works ala, now true RWKW not inflated. I'd hate to think of the true lower RWKW of a 93BP reading.
Bear in mind that Canberra is comparatively high altitude, so the BP should be lower.
From my perswonal experience there is one particlar e-bay turbo that is BAD - The '50 70' as some call it... This is the turbo on the MX6 link, and has nerouse bad reviews everywhere.
I have fitted the T70 to serveral cars now with excellent results, and seem to fine for long term also with the first that I fitted 8 months ago still going strong. They are rated at 600 so expected to be laggy.
I have also tuned 2 CA1DET's with the KKR 330 and KKR 430, the 430 was fairly laggy on the CA, but the 330 gave me the biggest shock! 206 rwkw @ 16 psi with awesome response.... I am completely confident the 430 would be an excellent turbo on a larger capacity (2lt or 2.5lt) motor.
Summary:
EBay - '50 70' = BAD
EBay - 'T70' = Good
KKR - =Good
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
