  • Replies 297
Posted Images
^^ nice engine bay.. wot silver did u use and did u clean/sand the pipes before painting??
Paint stripped all parts, then gave it a light rubb with 320
Spayed them with 3 coats of edge primer, this gave it enough build to remove all grains and edge primer is very easy to rub.
Spray a quick guide coat to sand it back with 800
Applied about 4 coats of silver, then 4 coats of the candy purple (the more coats the darker it gets) and then 4 coats of clear.
My mate owns Xclusive Colours in Smithville so access to this stuff was easy :dry:
The silver used is corse silver mixed with the new Mazda white pearls
The purple I will keep a secret, might be using it on other things. But there's alot of colours and pearls in there to create that colour.
Black CAS looks awesome Sean in that bay!
if your keen one day - come around and i'll "chrome" coat that lower outlet pipe - should get it close to matching the twin turbo pipe.
Hey yea when i did my rebuild i saw a really nice gold on these rims and i got the guy to do my covers for me but having seen the purple one on the previous page i am regretting not doing it a custom color shiz!!!!!
I dont mind mine atm no one really does them gold anymore Golden heart for my baby!!! but im having some serious problems with dressing my engine bay up if anyone has some ideas for me plz post its so depressing i want my engine bay to come to life wen i pop the hood i wan colors bit of chrome not so much dullness!
952328092008828.jpgImage Hosting
_K1NGTR_
start with the little things - remove and polish the throttle linkages
paint teh CAS
little bits and pieces til you get to the point of having to tear it all down to get the Plenum and twin turbbo pipes etc etc
BUT!~!!!!!
think of a theme and stick to it .. needs to all work together
yea thanx for that man the cars getting resprayed atm so i should pull little things off here n there. any idea where i can get the chrome pipes from the turbo that everyone seems to have?
you have to take them to get chromed :P or polished
and to replace those big black pipes with alloy ones usually means an aftermarket intercooler kit.
yea yea thats what i meant the after market intercooler kit and like the piping to the air flow meters i want to make them metal but i will get there eventually..........i hope lol
  • 1 month later...
After reading this thread and looking at some good results I decided to do my RB25. I used Holts MetalCast Anodised Blue, which has some mixed reviews. However I have found the reuslts to be fantastic.
I started with a good prep of sanding with 400grit then 1200 on both rocker covers, cam cover and the exhaust manafold shield. Used a lot of degreaser to make sure the surfaces was right. With the sanding I was back to bare metal in man cases however its hard to get all the little spots. Overall this took about 30min per piece.
I started then with the Hoyts MetalCoat primer, which by itself actually looks pretty good. I did a number of coats within 10min until the items looked perfect. Then I commenced with the color. Overall I did approx 5 coats with 10min of each over with th elast coat being quite heavy. Once they are left to cure, the anodised color really comes up, each bit looks really good however my camera could pic up the shine.
Once its been left for about 1 week I will start with a high temp clear to bring up even more gloss and protection.
Some of the pics from yesterday after I left them to sit overnight, bit of dust already on them! The gloss doesnt show up in the pics, but I can assure you its there in a big way. Need to learn how to use my new SLR!
post-27030-1225755109_thumb.jpg post-27030-1225755121_thumb.jpg post-27030-1225755126_thumb.jpg
^^ good work, i tried doing exactly the same with my parts but found the spray nozzle would dribble at time instead of spraying correctly, ruined the paint with blotches.. doesnt look like u had that problem though.. it does look great when shown in the sun..
hi mate, yeah I read about that but I had no such trouble, you have to press it in pretty hard and contanstly shake the bottle...once you get to the end of the can it can become inconsistant. It doesnt take long to sand back and give it another go..I redid parts of the cambelt cover and it now looks even better.
Just deciding what color to paint the coilpack cover, prep and base coat done already.
I got the cam covers, front pully cover and plenum powerder coated satin black with a slight wrinkle.
I'm thinking about getting the alloy intake pipe to plenum and air intake pipe to turbo done the same.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
