its munted, if it boots again be ready to get all the files off it quick smart.
data recovery programs usually only work if the drive works, try booting using Heirin (sp?) it has tools to fix up all major brand hard drives, might get her up n running again
i have a few paper weights like ur drive
I used to work in a computer shop and we used to wrap the drive in newspaper and chuck it in the freezer for 15 minutes or so. This seemed to give them a limited life to do some last minute grabbing.
That trick is limited to only a few models. Basically Seagate and a couple others started using a cheaper substrate for the IC's. Only problem is, once the substrate warmed up to 60'c, it became conductive causing a huge short circuit inside the HDD controller. Putting it in the freezer would cool the chip long enough to transfer any data off and onto a new drive.
-D
Luke I wouldn't even bother trying to boot off it again, you might really stuff it.
Pull it out and stick it into a machine that already has a boot drive and operating system in it then drag files across.
+1 to this. Your drive may only have an issue with the partition table. If you run a scandisk on the HDD from another drive you can sometimes recover it. At the least you'll want to find out if there are any reported errors from the drive itself.
-D
-D
We use that trick as well
but the HDD in antistatic bags and leave it in the freezer over night
and surprise surprise you can get possibly 30-45minutes of proper activity happening and get most data off that
after the 3rd or 4th time the HDD will be just as good as being under a 10 tonne press lol
thats how we destroy our work HDD's b***hes
might just be the MBR, does it get past post at all? if so u could fix it useing the windows disk
if it booted it wouldnt be MBR. MBR either works or doesn't.
Corrupt file tables will cause sporadic boot failure as data is written in places where it shouldnt be, or data is read from corrupted blocks.
-D
^^^ I've got the Logitech Pro9000 web cam - inbuilt mic, HD quality and great for skype HD video calls. Also, has some novelty features that your kids will like eg. a character face overlay that mirrors your expressions and face tracking. But, for something cheaper the Logitech S7500 has similar features to the above except no auto focus and slightly lower mp camera.
hrmm....I really like the twin pack idea and price of the Swann but I also like the hi-res capabilities of the Logitech Pro9000 & Orbit (Sphere) models
My vote is with logitech, since I've been using them for a long time. Theyre rock solid
-D
EB Games are having a massive sale atm fyi. Many games and other items are 2 for $50.
I picked up Assassin's Creed and Crysis Warhead for a grand total of $50 yesterday. Bargain - especially since Assassin's Creed was still priced at $89.94 and Warhead at $49.95.
Now I say good bye to another large chunk of my rarely available free time :D
+1, I have two of these, one for home and the other for work / on the road.
Great unit, never had any issues, GOOD quality video, not like most cams I've seen.
Not cheap, but webcams seem to be an item where you do get what you pay for.
hey Chops we should do another beer with Andrew sometime.
thanks for all the responses guys, I've checked a few reviews and am definitely leaning towards the logitech (buy it once I suppose)....just have to decide whether to get the Pro9000 or Orbit (Sphere)
If anyone here uses steam, just be careful of someone with the username Mor.B.Z.Wojtaz // zagram mixa // and if you get sent a link to here http://newsteams.tk/ - DO NOT LOG IN, its a scam website to steal your steam details. A mate received a message from him saying he had won a free copy of left4dead and GTA4, and to claim log into that site, but hopefully everyone here is smart enough.
Also on a side note, Pete, how are those hard drives?
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
