Bro, clearly all go and less show - my style! Nice and clean - has the goods. I like it.
Damn, any vehicle that runs a 13 sec pass is damn fast. damn fast.
Hit the 12 sec mark and you can call your beast - FAST...
Good luck... hope to meet you soon.
REgards,
  • Replies 172
thanks man, just got it running today, haveto run the clutch in and still get it tuned with the z32 and hook my boost controller up, f**k it feels so good driving it again!!
my first full build up!! and at the age of 18!!
I feel ya G - damn tight.... good shyte... start early as when you're older, you got no money and no enthusiasm.... i'll be watching closely with interest on your beast.
car was tuned today.. made 206kw at the wheels on 14psi standard turbo and actuator.. actuator is letting us down with not holding boost but shit happens..
MASSIVE thanks to rob and daniel at creatd motorsports... they go to all lengths to help you out on anything that is needed, i cannot hold them high enough..
went to calder drifts had a ball there, but bowed out mid way thru the night due to a broken water pump...
i want to put a koyo radiator in now with another std rb25 pump... which koyo do you guys think is good? the type s seems good for under 500 bucks...
Nice Build up mate. should be the goods with that 30/40 strapped to the side. Just remember that its not only the bottom end that will break, gearboxes and axels will go aswell with 340rwkw and slicks on the strip...unless your real easy on the launch. but hey all the best and i can wait to get my new turbo on my car. mine is i bit more bling bling than yours tho.
Andrew
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
