as most of you know the oil filter on the r32gtr is in a shit of a position.....
how in the f**k do i get it out? i dont want to put a screw driver though it cause im not sure if i could get the new one on and tightened
are there any tools that would help?? i was thinkin bout taking off the intake manifold
what do the rest of you guys do??
https://www.sau.com.au/forums/topic/110150-changing-oil-filter-on-r32-gtr/
cant say the same for my GTR. i noticed that the oil filter has been relocated to the front. go to Repco and ask for an oil filter removal tool, i cant remember the name of it, but ask em for the one with three claws on it. you need a shifter for it but they work best, or you can use an old bit of seat belt strap. when you put your new filter on dont overtighten it cos it can damage the thread and makes it hard the next time you change it.
Its a real bastard with the HICAS units in place.
Like edspaged2 said you need an oil filter removal tool, it fits on a 3/8' ratchet and will undo it. THen you need rubber arms to get the damn thing out.
Back in is easier since you don't have to do it up too tight :mad:
What replacement filters do you guys use? Mine had a genuine jap nissan filter on it, bought a ryco replacement only to find its much bigger and literally cannot fit down there (something driverside of the filter location is too close).
I have a relocator kit but didn't have the patients or time to try and get it fitted, it's hard enough just fit/removing the filter where it is let alone trying to get a relo kit down there (which wont be long enough anyway).
Edited by benm
Well after consulting www.rycofilters.com.au I got the Z145A (pretty much the same filter for all Nissan Imports).
It's about 2cm larger in diameter than the nissan filter (#1520853500) and I spent a good 5min trying to get the damn thing on after dropping the oil but I either wasn't lining it up properly (can barely get my hand down there let alone fiddling around with a filter as well) or it was rubbing up against something beside it (driverside).
Edited by benm
Any ideas on how to fit the oil relocator? Can you just drill pilot holes and then bolt it to the engine bay? Or do you need to rivet it in?
Nah, you can get one's which just screw in, but there are one's which come with little screws so you can drill pilot holes to keep it firmly in place.
  • 2 months later...
FYI: to remove the filter, you need one of the large bottle top openers. you can get them from hardware stores like bunnings/BBC for about $10.
they are usually plastic with an adjustable rubber lash/lead. these are perfect mothers day presents which is why I originally bought one- no more "can you come over and open a jar for me"
They are perfect for oil filter removal so I bought one for myself
I am an avid believer that tools should not be used for any other purpose then it was originally designed for however working for a rally team makes you improvise- cost vs. benefit of this is excellent! for what it costs, I would use it as a hammer if I needed to!
for the gtr, loop it around the filter and pull the lengthening strap tight. it wont sit flat but close enough is ok. Make sure that it is between the plenum and fuel return/feed lines- closer to the strut tower, not the dip stick- push towards the firewall!
it should come straight off!
I found a really good removal tool in autobarn (believe it or not) It has a threaded adjusment on it with a small handle so you can really tightening it down onto the filter and then you dont have to hold it on there. All it needs then is a crack to the left.
I don't know how you guys get these tools down there, I can barely fit my hand down into the filter area...
ditch that ryco shit. buy a genuine filter (and make sure it's the right one too). that will help. then invite over a 12 year old, or someone with really small arms and make them do it for you.
  • 7 months later...
i dont know where you get your ideas from but just so you know ryco make all the 'factory' filters in OZ so there stuff may have a different cover so if you get the right one it should fit as well as a genuine nissan
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
