Anyone who's having problems with their pictures displaying, please post in this thread here: http://www.skylinesaustralia.com/forums/in...howtopic=166435
So we can try and figure out why it seems some people can see the pics fine, while others can't.
-Insu
Did this one yesterday, there was alot of build up in the idle screw. Clean the lot with coton wool, then used the air gun to dry it all off...
Only problem i had was the hose at the bottom, what a pain that was to get off. Other then that it was all good
Nice write up :bunny:
  • 4 weeks later...
  • 5 weeks later...
Well this is my first post but I have to say what an execellent thread. Thanks for effort you put into this. I have been having idling problems since I had some new parts on the car I will give this a try first chance I get. Thanks a bunch from the UK Insu, I just hope the R33 GTR is similar to yours. :)
MidNite
ok stupid question i know but how far do i turn the idle screw in on the car (not the cpu) after i have cleaned it?
I have completed eevey step but not sure of where to set it to start the bottom steps (if u follow)
thanks
seems my car does not adjust its idle???
i tried screwing in/unscrewing the idle screw on the aac valve, nothing happens... sits at 900rpm
disconnect the TPS connector, does nothing.... still sits at 900rpm
what could be wrong?
Just another member saying this is an excellent guide! Did my car over the weekend and worked a charm, has never run so well. Mine was so filthy im not surprised that it made such a difference.
Cheers!
  • 4 weeks later...
  • 3 weeks later...
WOW this write up is sweeeeett!!!!!! iv had my r33 for around 10 months and im ready to burn the damm lemon over and over again!!! i have had idle problems from the the day my warranty ran out even total random cylinder miss fire iv spent roughly over $5,000 replacing part after part etc...etc.... but hardly no progress but i havnt tried this yet by chance the gods have forgiven me and this finally puts an end to my sorrows cheers keep you peoples posted
  • 3 weeks later...
  • 4 weeks later...
Your problem is with the IAC valve. (cold start idle up)
Its located on top of the inlet manifold roughly below where the throttle body resides.
The spring can flick off and result in a constant high idle. OR it becomes gummed up and sticks a little.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
