Hi all, i have a question, my 25, i built it, got it tuned (about 320rwkw), found out about oil problems, got scared and pulled engine out to fit restrictors and make sump bigger. To my horror the bearings were totally shot, and had been running dry at times obviously, anyway thats sorted, whole bottom is getting blueprinted as we speak. But what i want a second opinion on is, is putting a scavenge pump from rear of sump pan to front unnessisary? Iv made sump bigger, about 1.5L, and its baffled and gated, modified pickup, i have tomei pump set to 65psi. head restrictors, rear head drain etc. Reason i worry is when i do a hillclimb race of any sort, when pulling huge revs for really long times up really steep hills, will the oil flow back to front of sump? or is it a worthy setup? Its predominantly driven sensibly on the road, but i will do the odd race and track and skidpan day.
Now everyone will say go dry sump... Iv considered it, not going to do it the aircon is too valuable around here. plus its pretty dear. And i dont bash the limiter, so the tomei should serve me well. Iv probably missed some details... thanks
No i havent yet, but they look great? nothing restrictive about them. or do i need to take them oversize?
Now, plenty of oil?
Does anyone know if overfilling a bit is bad? what happens if your crank slaps the oil?
Now, plenty of oil?
Compare the half a dozen tiny oil drains in the RB to the 12 x 14mm oil drains in a JZ
So yes they are restrictive, most guys drill them out by 1mm as there isnt much room to move.
So drilling out the drains in the head and block. How do people actually go about doing this?
Just grab the power drill, a 9mm drill bit, some cutting fluid and go nuts?
Do they get a workshop to do it.
Or use a suitable drill press?
ok so no real problem with an overfill, ill attack the drains on weekend.
Has anyone experienced oil problems with restrictors and head drain with bubbles or starvation up really steep hills with big power?
I was going to use a 10mm bit unless anyone knows better?
This is for the rear drains yes, but what do people do about the 8?mm holes in between the cylinders?
As above run a 10mm bit through although it would be nice if someone could confirm having done it themselves.
I run 10mm, no probs at all.
die grind rear drains, drill others as they are round
Edited by jangles
The question still remains though. do people just get out the power drill with some cutting lube and drill out the drains to 10mm in the head and block and then chamfer the holes with a deburing bit.
Or do they get a machinist with a drill press/cnc to do it?
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
