Lol
Thats funny. I punched the matching hole in the back of the head. In the first photo you will see it. Like i said its all was experimental
But seems to work. I will remake them all out of aluminum soon as i dont have a good tig welder. And its not a ac/dc high frequency unit. So i was stuck with making it out of steel
Im suprised at how well it works. Trust me mate. The finish product looked way better and turst me when i say there no rust on the end unit.
I'm not convinced that your steel box is the answer. There is a theory that much of the spewing out oil problem is to do with correct fitting of rings (not so much with RB30s where the crank action is suspected of much of the problem) and maybe that is how you have succeeded.
However if you have no problems well done.
BTW most engine installations I have seen don't have much room for a steel box (rusty or not) in that position!
Yes i agree. Its fits perfectly. I do agree with the rings part. But as the motor ages we will see. But comparing to other setups at high boost levels i would see signs of oil. I wouldnt install rusty box to flow oil through as that would defeat the whole point. I feel from all of my test that the spool head drain doesn't work to well it just gets pluged and all it is, is a nicely shaped peace of aluminum with literally a hole drilled in it. I feel the oil pools and builds up faster than it can drain and blocks the factory ports. It gets more complex in cornering g's.
I have been messing with all sorts of ideas over the past year or so. Buy pooling the oil lets say in this rusty old box here. The weight of the actual oil helps to drain it back way way more efficiently. Rather than having the same idea happen in the head and overwhelming the factory hole by the last to rearward head bolts. This thing works like a water fall and frees up losts of breathing. One big down side we had was gear box swaps the engine couldnt tilt any so we had to drop the subframe till we got the box to fit then lifted it all in place. It was a pain but using a car lift the second time worked well. The benefits really out way the extra work. I do agree also with the additional stuff mensioned here as well. Properly picking the right size restrictor vs oil pump and rpms. Crank collar or newer crank. Exstended sump with good trap doors baffle. As well as good venting high above oil level. I found the rb25 to be a tougher at doing this. Without starving lifters of oil. So we approached it abit different.
Edited by MJTru
  • 1 month later...
Talking about blowby and catch can set ups....I was wondering how the Integrated Motorsports R34 GTR and Steve Ka/Powertune R34 GTR got rid of the bleeder hoses coming off the valve covers? Makes the engine bay look a shit load cleaner. I know the JGTC rb26dett's were very similar, so my guess is the dry sump oil system. If anyone has some info or other ideas let me know.
  • 5 weeks later...
as my thrashed car gets older i have now added a accusump and activated the external scavenge
which has made the oil pressure awesome one left handers however its now blowing oil out the second catch can breathers
so i have now added a one way -12 valve to the front catch can to stop oil being pushed up the drain
will report back if awesome or not!
I ran my set up right up to 8800rpm at 2 bar (740rwhp) around the track with sticky R-comps the other night and not a drop out of the catch can.
This is with no oil restrictors to the head and a stock bottom end, venting the sump works
  • Like 4
So would you say an easy improvement without tapping the sump would be venting through the dip stick?
Edited by XGTRX
I don't think the dipstick tube compares with two half inch vents.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
