post-16324-1143457856.jpgpost-16324-1143457715.jpghey guys
im getting my 32 gtr painted next month and really not sure what colour to pick its ucurrently black and iv got three colours in mind
mdnight puple 3 , the 360 spyder ferrari yellow or jet black with a pearl
Hey
I'm also considering getting my R32 GTR painted
I've always thought that lighter colours look best on the R32
I'm going with yellow I think
Will the underbonnet and inside the doors etc?
If the answer is NO then i'd simply go with the same color as the original but with a nice pearl in it....
Having a Black exterior and blue under bonnet isnt a really good look
just like R33_STEALTH said, if your not goin to get the engine bay, underbonnet, doors etc painted and your only gonna do the exterior painting then go with your original colour. The last thing you want is popping your bonnet to show people the engine bay or opening the door and for them seeing you didnt do a full respray, by seeing your old colour underneath. It doesnt look good and you will be called a "povo" or "tightarse" :D
i got everything except my engine bay painted. my engine bay colour is black so i guess its not too bad, noone ever says anything. i actually had someone looking at my engine bay and ask "so what colour was it before?". i thought it was pretty funny.
ali-turko wrote:
im planning on the whole car been painted
Faarrrk!!! The WHOLE car? ...as in underneath bonnet, inside doors, underneath boot lid, engine bay...?
Thats a MASSIVE job! The car has to be stripped down to a rolling shell pretty much. Motor has to come out and engine bay cleaned and prepped. All the doors have to come off, as well as door seals and trim too. Interior has to come out(And im not just talking about the seats!)
I dont see it costing any less then 5-6K
Yes doing the whole car is a MASSIVE job.
Since your car & engine bay is black its better - its alot more obvious if you have it resprayed something like red and inside the bay is white.
if this helps
www.modifymycar.com
you can choose wat car you want (called skyline coupe in it) choose the rims you have and lower it to your specs and change the color and see which 1 you like best.
hope it helps
I'll be getting my 32 gtr resprayed soon too. Anyone got any pics of a yellow 32 gtr? I can't picture it looking too good in my head. My 3 main pics at the moment are bayside blue, dark green, or the new Mazda 6 phantom blue (green pearl).
Yellow?? wtf?
I think thats one of the poorest choices for a car (no-offence secur1ty)
My 32 is black, but when the previous owner chose to get it resprayed he had it done black again (thankgod) with a blue pearl and a small metallic fleck.
It looks black for the most part, but raven blue/black in the sun. Its the best option as you can get away without doing door trims, and engine bay without noticing.
Yellow?? wtf?
:werd:
Morgs painted his car dark green, very close to the dark green Subaru colour. Looks great.
If you're after a yellow GTR, Stirlo_GTR has one for sale that he painted Modena yellow. After seeing pics of R32s in Bayside Blue, I agree with the guys that suggest a dark colour. The black with pearl sounds very nice.
2.2c
There was this purple R32 GTR with the plates GTR or something like that in zoom [not a feature car but a write up on a track day]
The puple was dark but with a pearl. It looked much like that green in the link above but electic purple! i'll try and post up a pic if i can find it
Any way.... a dark colour is good on R32 GTR
Just make sure you have a couple of clear coats so get that lovely "sheen" on it!
I always like the VT SS common-hore blue.
My 2p
Edited by NAman
i must be boring as i have been thinking about gun metal grey for my GTR. (currently also gun metal grey). possibly with a little metalic in there. and of course plenty of clear coats.
question: what colour pearl would the colour coordinated reccomend to go over gun metal grey?
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
