  • Replies 234
So if I were to get the Nismo injectors (was leaning towards these anyway) are they a straight fit into the stock fuel rail? I've had a brief look around for an aftermarket fuel rail (HKS, Sard, GReddy) and there doesn't seem to be one for an RB25DET. Also would it be essential/recommended to uprgade the AFM with the injectors? Just trying to see how much I need to buy before I get the Emanage installed so I can do it all in one hit. I've already done the fuel pump and a Nismo fuel pressure regulator is on the way.
"Five days on an all sprout diet with a wall papering video and a crochet magazine and we've all turned into crazies!"
thanks for your reply man.my car's coil pack already all ****ed up by that.now I looking for the coil pack.be careful when you do it......good luck
  • 3 weeks later...
Does the greddy e manage with profec e01 controller monitor knock?
Is it possible to get rid of the speed limit and change the rev limit using the emanage?
Is it much harder to install on a rb20det? Lots of wire puzzling?
What optional harnasses do I need using e manage with profec e01 on rb20det besides the normal ignition and injector harnasses to do all necessary?
Seem not to find real answers on these questions in the thread. I hope I am not asking things wich are already explained.
  • 1 month later...
OK, so after almost a year of having the GReddy Emanage lying around accumulating cobwebs and dust, I finally got it installed yesterday and tuned. The tuner that I had chosen had no experience with the Emanage b4 but was keen to give it a go. But really, the Emanage is not that hard to tune or install when you have the harness kit.
Initially, with the following mods:
- Apexi pod filter
- Trust R-SPL FMIC
- Blitz SBC idIII
- MV Stage 1 shift kit
- HKS split dump pipe
- Blitz 3' front pipe
- 3' Hi-flow Cat
- Blitz 3' NUR spec exhaust
- Bosch 040 fuel pump
- BP Ultimate fuel
- Bald Hankook Ventus K104 tyres
The line pulled 148.3 rwkw with 10psi of boost. Now, after installing the eManage and a few hours later 198.4 rwkw was achieved with 12psi of boost. The turbo is still stock and so are the coils. The plugs haven't been changed in about 12 months but are NGK platinums with the standard gap of 1.1 (I think).
That's the good part of the story!
A couple of things that I noticed while the car was going through its last couple of runs was that towards the end of each run little puffs of black smoke started farting out of the exhaust. I was told that this was because the plugs needed to be changed and that I should shorten their gaps.
Another problem occured when the car was idling and the kick panel was being placed back into position. As pressure was applied to the kick panel onto the ecu, the engine would turn off. I was told that it was something to do with the wiring in the harness.
Finally, the last problem was realised a little while later when I had left the tuners. The car seems to want to change gears at higher revs which is really a kick in the back. I can induce a shift by fully, not partially, backing off the accelerater at a reasonable point. Now even with overdrive on fourth gear will only engage when travelling at 100 kph. Even at 60-80 kph and backing off the throttle, third will be the highest gear selected. Also, when the car is warm and the gear is put into neutral, revs will drop to 500rpm and start hunting up and down. It also happens when the car is started when warm.
So as you can read there has been a few positives and negatives to come out of my experience with the GReddy Emanage. Fingers crossed that these problems are not permanent and that are fixable.
If anyone, DAN666 in particular, can shed some light on these problems, could you please reply to this post. I'm going to check to see whether the tuner had missed something myself with a PC 2morrow.
wouldn't the car wanting to change gears at higher revs be to do with the shift kit?
No, the problem is not related to the shift kit as this was done b4 the tune and everything was fine. Its just not going into 4th gear unless I'm at 100kph and back off the throttle.
I'm just curious to know what was done on the Emanage to have this effect on the shifts. The Emanage only intercepts Air/Fuel and Ignition timing. Would changing the ignition timing affect shift points?
OK since the harness plugs into the ecu loom and also the ecu, maybe signals required for gear changes are getting screwed with before being passed to the ecu. And since the engine would cut out when pressure was applied to the harness then the wiring within the harness must be screwed. I may have just answered my own Q. :lol: Keep the suggestions coming in though!
Most likely due to the Emanage changing the TPS signal. Shift points are usually shift event vs TPS vs road speed. ie at 100% throttle the car will change gear 1st to 2nd at say 55km/hr. Although I cant really see any reason why they would have changed TPS signal.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
