  • Replies 234
Jay,
Significant gains in the low and mid range with ignition control combined with the big gains from fuel control up top make it a pretty nice package for the price. As for percentages they vary depending on your mods but 10-20 % average should be achieveable.
Doc.
  • 5 weeks later...
Part Number: No.15900903
Description: It is the adapter which prevents that ’xŠp compensation of the ignition time by the knock sensor is effective too much.
The signal line and ground of a knock sensor are wired.
It corresponds also to vehicles with two knock sensors, such as 6-cylinder vehicles.
Hi guys im new to the forum, nice to be part of the international Skyline scene! I have a R33GTST with HKS Super Powerflow induction, Trust downpipe, cat bypass and HKS super Drager exhaust. I`m going to be adding the E-Manage ecu soon and wonder what sort of BHP and general performance gains I would get running 0.8 bar?
  • 1 month later...
Hi all,
I'm currently using an e-manage on the CA18DET in my RS13. It works really well.
The software is very easy to use but you really need a wide-band lambda setup or rolling road tune it properly.
The airflow meter change facility allows you to swap the standard airflow meter for another one of the same type, I'm using a Z32 TT MAF with 460cc injectors at the moment.
A few weeks ago I started testing a 'blow through' setup on the CA18DET which has the MAF fitted between the throttlebody and intercooler. I got it running within 10 minutes and after a couple of hours of mapping its running well which shows how flexible the E-manage is
I'll be using the e-manage on my RB25 when it goes in the car in January and if we can get the blow-through setup working well on the CA I'll probably carry it across to the RB. :)
I finally put the e-manage in my R34, everything is going great so far. I also used the Field 'one touch harness' with it, made life 100% easier by not needing to do all the soldering while hunched over in the car :)
Sorry Ed didn't end up needing the ignition harness so can't comment on the whole coil frying thing.
From plugging it in I have noticed a slight difference in the shifting of the tiptronic gearbox.....it was tiny bit jolty between gears at very low RPM, now it seems to have disappeared?
Should have some larger injectors (~40% bigger) in the car by the end of today, so I'll see how it handles those.
Dan
Where did you get this and how much? we're having great difficulty sourcing the plug in harnesses for those who don't want chopped wires...
Doc.
You can plug it in straight out of the box, just as long as you set the three selectors behind the front panel...this just let's it know your cylinder setup, airflow meter etc...basically what model car you have.
As it isn't programmed..it just runs your stock factory settings.
I can’t see why it wouldn’t go on an R31, it uses an ECU and anything with an ECU (as long as you know the pins) can be hooked up to the e-manage.
I’m currently trying to find a harness to suit the R31, so I’ll keep you up to date
Dan
  • 1 month later...
I am excited after reading this thread. Before I sold my turbo maxima, I had purchased an E-01 (which I used and worked well), I also had purchased, but never installed, an e-manage. With my s13 r33GTR swap, I cant wait to get the e manage installed. You guys will hear back from me when that part of the game rolls around...
-ctn
No probs, mine is an auto as well.
There isn't much opitions out there for us auto guys and I think e-manage is the way to go considering the cost of it compare to Motech etc.
I recently just saw the e-manage drop again to like $499 brand new!! (without harnesses).
Even if the ignition doesn't work, for this price it is still better than the SAFCII and have better fuel tunning.
I also heard something about Buddy Club having something similar to an E-manage?!
There are 2 version apprantely and one version is actually made for autos.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
