Hey guys...
Long story short...
Its time for a wheel alingment before i scrub more rubber off my rear tyres after fitting a new set of springs and shocks. I have had many wheel alignments done before but its costlly and i have access to a brand spanking new wireless wheel alignment machine next saturday.
However this brand new fang dangled machine only has Holden motor vehicles programed into its data base. Probablly because its based in the workshop of a major Holden dealership in Brisbane. Anyways i need the numbers for an R33 GTS-T Skyline asap.
Spec on my car is lowered 1.5 inch's. I dont think anything else has a bearing on the numbers. So if you do wheel alignments for a living i would like to hear from you. If you have access to the standard numbers (settings) I would also like to hear from you. Its just i have a guy to operate the machine and he wants the standard numbers to punch into it so it can do its bit. As in toe in and so forth those who have the figures i am looking for know what im talking about.
Thanks Col
https://www.sau.com.au/forums/topic/112947-wheel-alingment-settings/
Hey guys...
Long story short...
Thanks Col
You have lowered the car, so the standard caster and camber settings are meaningless. If you haven't fitted adjustable bushes, you can't adjust them anyway. Actually you can adjust the rear camber 0.25 degree with the standard adjusters, but considering how much you have lowered it, that won't help much. From the R33GTST Whiteline and Bilstein Group Buy thread following are my recommended settings
Front
Caster +7.0 degrees or more
Camber -1.0 degrees
Toe Zero each side
Rear
Camber -0.5 degrees
Toe -2mm each side
Hope that is of some help
:thumbsup: cheers ;)
Thanks Garry
I just really need the tyres to stop scrubbing side ways down the road as my rear guards are always filled with rubber from just 100km drive...
Ill write em down... Try it on saturday...
Also i purchased a bush kit from whiteline pn: KCA347 but have been told they are useless and difficult to setup...
So i really just the wheels straightened to stop off centre scrubbing...
Thanks again
Thanks Garry
Thanks again
The KCA347 is a rear camber adjustable bush kit, very usefull. Whoever told you they were useless is probably not using/installing them correctly. Just follow the instructions.
:D cheers :D
Edited by Sydneykid
There was no instructions....
I thought my rubber was wearing from just sitting on the inside of the tyre but i have founds out it is not the camber its that the wheels are not straight...
As is they are out of wack in terms of toe in/out...
So i like the camber but i dont like the chewing of my rubber...
If you want good tyre wear then get SK alignment settings as above.
If you want better handing, then go a bit more aggressive on the camber...
It's a sliding scale between tyre wear and handling....
Eitherway, go get an alignment ...
when getting an alignment is there any danger? eg them fudging the hicas or anything??? coz i want an alignment done soon but im worried the local tyre power shop might screw it. plus ive seen them do an alignment... whip out the old hammer and give it afew wacks till its right.
I'm trying to find Sks settings for a standard R33..GTST
I'm going to get a wheel alignment soonish so was hoping to get all the settings to give them for 95% street used car running stock gear.. I looked through the group buy thread but couldnt see them listed in a clear cut manner. Should there be a FAQ or tutorial.
ie.
Front
Toe
Caster
Camber
Rear
Toe
Camber
+ any other settigns needed??
Thanks
Edited by benl1981
  • 4 weeks later...
Umm, the same settings should be fine for an r33 gtst, personally I would go only -1mm toe on the rear but Gary knows what he is talking about :ban:
There is one trick I have found with wheel alignment shops.....make sure they follow your supplied settings (ie get a print out from the laser aligner). If you leave them on their own they give the tyres toe in to reduce the impact of the camber on tyre wear.....which is fine if tyre wear is your only issue - but if you want it to turn in properly and be stable at the rear follow the settings above instead
In my r32 gtst i run
Front
Camber 1.5 neg each side
Castor is about 6.5 each side (can i impove this? i think its pretty much maxed out)
Toe 1mm out each side
Rear
Toe Zero each side
What do you guys think about this? Could it be improved?
Cheers guys
does anyone know a place in sydney that is good for a wheel alignment for skylines? trustworthy l mean, also mechanical work too l suppose.
Heasmans ,Sydenham
East Coast, Kirrawee
StGeorge Steering, Punchbowl
:P Cheers :(
hey,
i might have similar problem, just got the shocks and springs fitted today. but they didnt have enough time to align it. so will have to go tomororw morning,...but whats really bugging me is that...the height from centre of hub to top of guard are different on all four corners?.....is this what a wheel alignment should fix?
or should i be going back to the suspension place and ask wth happened?....
RHS front is 345mm but LHS front is 330mm
RHS Rear is 360mm but LHS Rear is 350mm
and its scrubing sometimes when going over a bump ont he lleft front, sounds similar to you Col-GtsX
is your height the like that too?
SK
With the -2mm of Toe on the back, does that mean the wheels are pointing outwards?
What effect does this have on the tyre were?
What effect does it have on the handling?
Thanks.
Alignment being done now, I just want to get the idea straight in my head.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
