Hi All,
Okay did a search on this and found heaps but none that really has the same issue as my car so, I got a dual stage boost controller installed a few weeks ago, got it set at 13psi, car is stock ecu only other mod is pod filter dump pipe and 3inch exhuast, the mech said these cars have a fuel cut at 14psi so if car feels like its missing its the fuel cut out cutting in, might happen at night when its cold as it might spike. So try it out one night and sure enough it starts to miss. Checked psi and was spiking so turned it down to 12psi, still happening, thought then maybe regap spark plugs, so now gapped at .8mm still doing it so turned it down to 11psi and still missing so went and got new plugs and gapped them at .8mm got copper NGK BCPR6ES still f**king happening!!!
I can progressively put my foot down and it won't miss but feels as though its being held back, its a constant miss not eradict, like its every couple of seconds and its the same all through the rev range, I now hav it at 10psi and this ain't much better than standard although is a bit quicker, but am i hurting the car somehow???
I'm at a loss people so any ideas would be much appreciated
Cheers Adam
https://www.sau.com.au/forums/topic/114981-car-stuttering/
its excess airflow protection, not boost cut. its based on too much airflow so the computer dumps timing and drops in heaps of fuel to protect itself. keep turning down the boost until you work around, try around 10psi instead
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2117210
I'm not doing your searching for you.
it's been covered more than flutter bro threads.
RB25's always have a miss when boost is raised more than a couple of psi.
they go rich to compensate for the extra air flow, and in turn retard and you have a flat spot or miss at around 5000rpm.
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2117563
See thats just it, my miss can happen from 2000rpm and up. As i said there is alot of similar threads but none like this, I'm not asking you to do my searching i already did a search but don't call me a liar if you can't back it up
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2117902
Thanks for starting this thread. My car is doing the same thing. I am running 9 - 10 psi and between 2500-3500rpm i am getting a stutter.
I few weeks back i replaced the fuel filter and the problem went away. However a few days after replacing it the problem has started again. ATM i have been living with it but it could have a dirty fuel tank?
Anyone else fixed this problem before?
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2119028
Okay ive heard of taping up the coil packs in alot of threads about this/similar prob so i'll try it but anyone got a pick of how??? i know i sound stupid in asking but don't want to do it and not do it correctly, cause it could be and if i did it wrong it it didn't fix it i'll be back on here stating it wasn't it! Then GTST will be up my arse and calling me a LIAR!!!
Thanks people, really appreciate it :)
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2119965
sorry to dissapoint you mate, but I'm married and to a woman so I won't be going up any part of you.
:ban:
if you take out the coil pack and hold it in the position you take it out of the car, I started taping (tightly) from halway up the rubber part all the way up to the base of the coil.
I went up going half over the tape each time round and then back down and back up and ended it there so it is like 3 layers.
try to get good electrical tape like 3M or something rather than those 6 for $2 from the $2 stores.
I haven't had any issues since then.
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2119986
well for starters i wouldnt be runngi 13psi on the stock turbo
so turn it down
I mean, other than that, it could be anything
Fuel pump, Spark plugs, AFM needs a clean... the list is limitless
I was under the impression that with stock turbo 15psi was the limit???
I can just about rule out spark plugs as it did it with my old ones when they were gapped at 1.0mm and .80mm and also with new plugs at .80mm so 99% sure its not plugs. I have turned down the boost to 10psi though last night found it spiking to 12psi so 'll turn it back down to 10 again and will post my findings.
To everyone who has posted thanks!
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2119994
:rofl:
Much appreciated GTST, by the way i'm married with two ruggys myself, so not dissappointed but relieved :ban:
What is your real name? where you from?
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2120005
there is no limit to a turbo so to speak.
what nismoid is saying is that the stock turbo on the R33 has been known to fail on higher boost levels due to the speed it spins at and the heat it produces.
so at 10psi it is about 3psi over stock and is quite comfortable for it. but no guarantees.
also, at 10psi, you might not get the miss caused by R&R with stock ECU.
what boost controller are you using?
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2120171
I have a GFB dual stage B/C. The mech said it shouldn't spike cause they're a good quality item, but it might spike at night cause of the air temp and stuff, which i understand the standard soleniod does on cold nights too.
I have a few things to check so i'll keep you posted
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2120199
I use to run a Turbo Smart Dual Stage..
Car had exactly the same problem, when you put your foot down the car would just splutter and jerked like crap... I think, yes think it was because of the boost spiking, and I was told by my friend to get it rid of it as he too had the same problem...
So yeah running stock boost now no dramas... ebayed the Turbosmart Dual Stage for $120... heheh
https://www.sau.com.au/forums/topic/114981-car-stuttering/#findComment-2120441
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
