I'm surprised no one said NOS ;P
but yeah, I'm doing my car up at the moment.
done exhaust, suspension air box(replacing with cone for fmic), strut braces.
got in shed, fmic, 040 fuel pump, turbo tech boot controller.
got to get a pod and I'm thinking about brake upgrade. but first I think I'll go too the dentist.
  • Replies 63
id get
neons
gauges that arent fitted
decals
and some soy sauce to go with all that rice!
just kidding. take a look at me signature.
if i had 5k and only 3 mods 'twould be. turbo upgrade+power fc+ fmic
cheers. james.
if i can afford they will be:
Os Giken RB30 bottom end with a totally rebuilt Rb26 top
Twin Trust TD06 turbo
Motec M800
Edit: my gear box will be long gone which means a Os Giken Sequential gear box will be needed as well.lol
money is a terrible thing, isnt it.
Edited by frankxy
For '3 items' Id do it wisely and look for some second hand near-new items (go ebay!) and get some new items at discount prices (forums are good for this). So itd have to be 3 different areas of performance for me to justify my cash (my car is auto 4wd Stagea):
a) Exhaust/airflow = full exhaust ($1000), intercooler ($750), CAI box with pod filter ($250)
b) Suspension setup = most of Sydneykids suspn group buy kit ($1800)
b) ECU's = Apexi SAFC, Apexi SITC, Electronic Boost Controller, all dynotuned ($1200)
Around 5k. Ive already done all this and more for a total of 7k, lots of mods. =0 Next one for me is the turbo to make it all 'work together'! :P
My budget is around 12k of mods on top of my 18k car, over a couple of yrs. If you do it wisely the money can go very far indeed.
Edited by Tangles
Well, my car had a rebuild by the previous own so theres a few thigns in there that I can't guess the cost of.
For me at the mo its..
1. PowerFC D-Jetro, EBC and tune - $2552
2. DBA4000 rotors and Ferodo pads - $500
3. Accessories (wheel, knob, etc :D ) - ~$?
So far for the Galant I have TD05-16G Turbo, Chipped ECU, 055 AFM and Intake Pipe, 720cc injectors, and a Bosch 040 pump all sitting in a box waiting to be fitted. about $1270.00 so far...
17x7's and 215-45's went on a couple of weeks ago $1080.00 from wheels-online off eBay...
My suspension was already done when the car arrived but a whiteline rear swaybar would help turn-in, $370ish...
Boost controller on the way from Nengun as I type, $417.15...
Exhaust also done, but intercooler piping needs to be upgraded to 2 1/2" $450.00
Need a Dump pipe (about) $650 clutch $400ish and a LSD for the rear diff $????
By my calcs that comes to just about $5k without the diff.
Put together and driven right that's a recipe for a mid-low 12sec VR4 (ok, maybe not with my stiff suspension)
Damn I need that last grand.......
$300 for a dump pipe, max
Unfortunatly the dump for a VR4 is like a dump and front pipe in one with a flex section in the middle, a decent, split dump that doesn't obstruct the oil filter is not easy to get and not cheap. Almost got me looking at making my own if I can co-ordinate the borrowing of a machine shop and TIG.
Edited by PTR33
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
