  • Replies 109
Posted Images
what plugs are you running, and also what gap, try 0.8mm and see how that does, if not go to 0.7 and then 0.65mm.
Mine ar at 0.65 as when it gets dam cold here in tas, the air is so dence, the mixture is very hard to ignite, and my coils suc
Even with splitfires Im running .8 gap as I still got missing at 1.1 (indicating possibly ignitor or something else?) Generally only after Ive babied it around for 50kms so it could just be that the plugs are fouling up. On a cold night it runs really well.
ok got some different coils.
Still have the miss firing problem.
Are they still the VN coils? VN owners look for replacement solutions because of their poor performance on an NA engine, they wont ever work well on your motor.
Edited by Rolls
  • 3 weeks later...
iv been lookin into this and by the looks of the au coils all 6 and built into the one unit? iv been lookin round on ebay n can u use any type of coil? i understand how it works but dont understand the wiring side of things.. could you remove the coil pack loom n make a new one from scratch?
http://cgi.ebay.com.au/NEW-MSD-HIGH-VIBRAT...1QQcmdZViewItem]coil system[/url]
in the link can this be used or way off? is that to run all 6 or do you need one for eash cylinder?
i find this abit confusing but im very keen to get my head around it n get it workin good
thanks
Edited by 2gceffy
my pricing is brand new leads and coil pack through repco but at mates rates..
pfft ford.. who would want a ford part on there car.. lol its bad enough we have mitsi parts running our engines
Give me a ford TYPHOON any day smoke back nearly all our cars
VN coils are known to be shit.
Use a VP coil pack, its what is recommended when replacing coils on ones VN dungadoor.
Fords better than Holden anyway. Holdens 'feel' cheap and rattle after a few kms. :)
The VP coils really do throw out a fat spark, I've seen one that I was testing jump ~6cm's and it was fat as, I could hear the crack.
Has any one ran these VN/VP coils at high rpm 7000-8000rpm with decent boost?
  • 3 weeks later...
Hay guys, i have all my bits now, just need the Coils, whats better to use.
AU S1 Coils.
VN Coils or
VP Coils.
I am also using a S1 ignitor for an R33. Mine is a S2. I have made a plug that goes form S2 loom to S1 ignitor and onlt the coils.
I hope this works, i would hate to spend money and get nowhere.
cubes i regulary run the r33 using the vn coils to redline running 13.5 psi gapped plugs to 75thou.I dont no if thats the sort of figures ur after but it has missed once when the plugs where at 1.1 I will be upgrading the vn coils with msd shortly
So which to get. You see mine is a S2, so i got the ignitor, but it is going to cost me another $90 for plugs to make up a harness between the S1 ignitor and the S2 loom. So all up looking at close to $300. Now i think it might be easier to get splitfires.
i hav done 2 wasted spark conversions 1 using a vp coilpack into an rb30det and a mitsubishi diamonte v6 into my rb20de.
at first they both went like shit on a stick there was a huge diff in acceleration and the idle was mint.
as far as i know the mitsi alternative has not relly been tried but it cretes a huge spark it manager 2 jump out of the ht lead thru another 3 cm to the plenum so thats about 6cm in total.
but after about 3 weeks the rb30 stopped makin spark all together when it was taken 2 the tunors he said that it was because the r32 igniter was not compatible with the waisted spark and the charge times are diff so as a result we had been over working the igniter this resulted in the link ecu needing rebuilding and a new igniter out of a mitsi or holden needing 2 be rewired in its not yet back from the tunor but il keep u updated.
now for mine. the rb20 didnt give me any trouble until all of a sudden it stalled when i left it at idle n it refused 2 start there was full battory but it would only start when i pushed it once i got it going it didnt give me any trouble till the next day. it started first pop but on my journey i pulled over and left it idling again when it stalled it would not start under the battory and i reset the ecu several times. that night i towed it home, i tow started it a couple of times on the way home and it would only idle and not rev the minuit i touched the accelerator it would start missing and then stall unless i quickly pumped the pedal. since i got it home it will idle and start under battory but still not rev i have restored the factoy coils and that didnt fix it i also tried replacing the afm i hav the hunch its the ecu and will be replacing that soon 2 c what happens.
im prety sure the rb20's problems are a result of the ignition mods but if any1 can can prove me wrong i would be quite gratefull
the rb30's problems are deffinetely a result if the coil pack mods
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
