i meant with the monthly cruises!!! Everybody voted to have a cruise on the first Tuesday of every month meeting at 730pm etc etc
and i wanted to know if it was going to happen :pirate:
I'll be going on the Bunno cruise tho
  • 3 weeks later...
  • 3 months later...
  • 2 months later...
The thread got deleted where i asked this last time: Whats going on with the monthly skyline cruises?
Pretty sure someone said the dude who does them left.
Whos responsible for cruises these days?
I checked out antilag and they don't seem to be too friendly with their attitude of "if its not performance, we'll tell you to leave".
I see there's events coming up on here, which is good.
Hi Everyone
Looking for interest in anyone wanting to do a cruise down south around the coast and through wine country.
Bunbury - Dunsborough - Yallingup - Caves Road - Margaret River - Bunbury.
I did this run a few weeks back and it was an awesome drive and took about 3 hours including lunch. Also had some very nice coastal spots for photos etc.
Anyone local or from Perth then let me know and I will put something together for April sometime.
Blinky
Afternoon-ish cruise with overnight stay as a group (to help keep the cost down) with dinner & probably drunken shenanigans would be good instead of having the majority of people driving back later :P What do you reckon?
Plan B is everyone bunks up at your house. Kek
i'd be in for cruise down south say cruise down sat and stay sat night in a town?
i'd have to be home though which is always a problem for me lol i gave paul a couple of dates that im home :P (basically home every 2nd week, this includes tab (passive) as well)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
