Well I'll organize one then for the week after next sometime. Cool cool?
First person who answers this gets the prize. Should this be mid week or Weekend?
Actually if it's a special night I vote make it a weekend night
And should it be an open cruise? Or shall I make another golden era FR sedan cruise... Bear in mind I no longer drive an FR sedan :(
I reckon FR sedan cruise would be sweet... Get Toyota crew on board this time
Or how about golden era JDM cruise? I like that idea
Edited by Mr Eps
Okay so let it be set. I'm organizing a huge cruise for you all in the near future. It will involve all types of cool stuff. Sooo watch the events section in coming days /weeks and let me work my magic!
Edited by Mr Eps
Oh my god. Yes. It can not be that hard surely.
Have you got a Japanese built or imported Japanese car?
Is it so good looking that you want other people to see it?
Is it built during the times of when Japanese cars were not eco friendly hybrids?
Do you agree to not drive or behave like an idiot during the meet and cruise??
If you answer yes to all of the above. You will be welcomed with open arms.
Gold era is basically 1988-2000 built cars.. But obviously Newer cars can come so long as they look incredible.
So I can come. :P Just joking.
Well, thanks for organizing, Rowan. I will definitely come if nothing urgent comes up on that day. :)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
