Trolling/abuse
QUOTE (SAU (WA) WASTELAND RULES 2008)
(a) Exercise common sense and be considerate toward your fellow users. Diversity of opinion and intelligent civil discourse is encouraged; by the same token, insults and “flaming” are not tolerated. Disagreeing with an idea of another community member is different from attacking that individual.
Truck drivers who are so ignorant they dont stop at stop signs and decide to cut me off while im doing 80kph. And then has the courage to hang his bogan arm out the window and hound me for his mistake. Not much needs to be said other than complete douchebag!
wgmg :)
my brother
my brother saying if you had abrain when he has trouble reading
the learners permit age
that nothing is cheap [$3 for a can of coke at a servo]
that ill own nothing because of bligh
that i live on 2 acres and my dad wont by me a car
my mum's nonability to drive in a straight line backwards
EDIT: gt5 being late
wat doesn't :)
5 in a row for state of origin
natural sellection
Edited by sleeperdatto
moderated threads for selling =x
i know sometimes people post silly things...but threads dont get updated unless a mod is online.
Car for sale threads get updated within 30 mins on weekdays.
Weekends and nights it takes a little longer.
We're testing a few different alternatives in the parts section so it may be a little behind right now.
We don't put these systems in place for our own entertainment, they are to benefit the forum/forum users. So we appreciate your patience :P
spending a good hour mounting the office media server on new server rack mounts, adjusting the size of them so they fit in the rack in my office rather than the server room, go to turn it on and having the fan louder than a a380 loosing an engine....
EVERY THING :)
nah but what really grinds my gears is popo that hide speed cameras behind parked cars
the emergency department at RPH
ppl that go to emergency with blood noses and splinters, im not kidding
the fact morphine does nothing 4 kidney stones but thats all they give u. f**k give me a tranquilizer. next time im just going to take nurofen plus and tramadol and get a high as a kite
and not forgetting youtube adds for good Charlotte and short stack brrr
  • 4 weeks later...
  • 5 weeks later...
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
