  • Replies 191
Posted Images
hooley dooley 21 mil!
well i reckon they would have made a mil back at least... i never saw one person walk or drive out with any less then 3 dozen... and i would say there would have been at least 10,000 customers... probably a lot more.
yeah, went there the other nihgt, began to line up.. like 300 cars in line :D.... got there at 2 in the morning... i rang some sick muzza coz hehd his mobile number plastered accross his back windown.. he had just ordered.. .. asked him how long he'd been waiting... he said since 10pm :) WTF 4 hour wait... so i turned around ... wasnt gonna sit there for 4 hours... no way
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
