Thats awesome. The Japanese police have been using skylines as police cars for bloody ages! ive got this old 80's movie called "Too Much", about this girl going to Japan and making friends with this robot. Pretty strange. There are some car chases in the movie involving the police and you can see the old Skyline police cars. Im not familiar with the old school ones though. They had the rear view mirrors on the front wheel guards i think?
Yeah, what are those shields for? Stopping bugs from hitting the windscreen? If you look closely at my avatar pic, the old R32 GTR cop car has it too.
Edited by edspaged2
I'll take a guess that it's to help deflect the wind-blast over the top of the ski-bar on the roof.
I know that when the Vic police first got the VN-VP era Commonwhore chase-cars in the early 90's they were "un-officially" speed-limited to around 225kph 'cos above that there was no guarantee the gear on the roof would actually stay on the roof.
Supposedly they had 1 set come in the rear screen & another spear thru the rear door-skin at stupid speeds which was obviously not a good thing, for them anyway :(
those are pretty sweet. i think somebody in the local government saw them and decided to do something as close as they can to use R34s as our cars (damn 15 year rule)...
yeah, dodge didnt rip off the look at all :worship:
Edited by entelijint
I believe that the shield is for bugs and other debris.
The gold badge is the Japanese police force badge as shown below.
This paint scheme has been used on Japanese police cars for a looong time.
Here are some more police cars :D
Mitsubishi GTO with those "funny mirrors"
Nissan Skyline V35
Mazda FC RX-7
Mazda FD RX-7
Honda NSX
Undercover Nissan Skyline R33 GT-R
Subaru WRX STi
Nissan Cedric
Nissan Fairlady Z (Z32)
Nissan Fairlady Z (S130)
Nissan Fairlady Z432 (S30) and Fairlady Z 2by2 (S31)
Nissan Fairlady 240ZG (S30)
Mazda Cosmo 110 Sport
So, who wants to join Japan's police force?! I do!
Edited by Alfadog
Supposedly they had 1 set come in the rear screen & another spear thru the rear door-skin at stupid speeds which was obviously not a good thing, for them anyway :thumbsup:
When I worked for Dominos they told us not to go above 80km/h or the sign on the roof would blow off , well they were wrong it blew off at 90km/h
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
