  • Replies 99
Posted Images
One day .. maybe in like 5 years my next car will (hopefully) be a s14 that I can whack a 180 front on.. big wide bodykit.. roll cage.. etc mmm track car.
But if you want to keep your import but have a 'legit' car why not just get a s14 or s15? A lot of business type people own those (... and don't DRIVE them).
P.S. I should also suggest that if you're a high profile employee who can actually make it a talking point and turn it to your advantage etc then it's actually a good thing to be able to have something that stands out. I see people in 200's and other German ford-laser level cars (318's etc) and it seems to be very very common..
For example I'm in a consultancy role at a major and stiff financial company... Whenever I get the chance to go to things in the cefiro I do, it presents like a piece of shit compared to the other cars there and it's not like these people think it's PHAT because it has dish, a kit and induction noise etc, nor do they care how it handles, drifts or goes... But they remember me and the car and think "ahh that bloke likes to modify cars".. That gets me into their consciousness, then it's up to my skill and competency (and bullshit skills) to sell and build credibility..
Other people use other ways to be noticed, like they fit in, work hard and hope they're noticed that way... *shrug* horses for courses mate but either way good luck :D
What does everyone else plan on buying for their next car? Another skyline or a bigger car because you now have a family or.............?
Cheers
Id suggest a nice Series 2 model Stagea.
Whether that be a RS4 (RB25det) or a RS260 Autech GTR Stagea wagon (RB26dett) thats up to you and the wallet.
They look nice, rare, and go like the clappers.
Edited by Tangles
Ferrari of whatever current model.. :P
hmm.. maybe chaser jzx100
Then again, the 'practicality' of a 4 door is not much better than a coupe when it comes down to it (having owned a few)... You still don't have enough boot space for the big long or larger items. For that you need a hatch or a wagon. The only thing it's a bit more convenient for passengers, and well stuff them :D
If "class" wasn't an issue, I'll just keep my R32.. for price, handling, performance (having turfed the rb20), knowledge of the car, power/weight, there isn't much better. It's a bit daggy on the inside these days, but then again what isn't unless you bend over on the price. And whatever else "new" will be ever-outdated in 3 years after that. Why keep playing the game until you die purchasing new cars every few years and blow it all over again? To me that's lame. During that time you could be travelling overseas, buying a business, going on exciting weekend adventures, furnish your house with the best furniture, etc, etc rather than spending maybe 40% of your weekly income maintaining some new car.
I was thinking no matter what you're going to buy you're going to get shafted with the resale and that never makes you get richer faster, so why not just stick to whatever you've blown all the money on
Why not get another Nissan - the 350Z ?
You have a choice of Coupe or Convertible (My wifes choice - her Turn next)
And it would be a corporate approved conveyance :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
