I've just redone my light/moderate load ign. and afr's...
Should be interesting next tank, the ignition has actually made quite a difference to how the car feels off idle, prior accelerating from a standing start in second would have it bog for a fraction of a second, now it simply accelerates without bogging. :D
I've got a real strange issue around 2000rpm as the turbo tries to make more than a few psi, it appears to bog, boost goes up, afr reading goes way lean then as soon as it gets over 2000rpm it clears its throat and acceleartion literally snaps on.
I'm assuming this may have some thing to do with the n/a cams running around 8degree's overlap and such a small turbo.
Nothing I do will get rid of it, super rich afr's, lots or little ignition timing or a mixture... Buggers me.
  • Replies 58
Question... i have rb20 wit z32 afm/gtr injectors and im gettin 300ish kms to a tank, i had standard injectors and afm and got around the same, isn't that abit sh*t for an rb20?? I would like some fuel economy but if i cant have some decent hp and economy, well i did buy a car with a turbo n id understand lol Ive just seen some figures off rb20s and even rb25s that blow me away, even with i baby the motor!
Edited by jazza08
Its all about maintaince, I'd also have to say (in my case) it doesn't have so much to do with tuning as on the base pfc maps with z32 and gtr injectors & the 3ltr I was pushing 440km's per tank.
The only time i've dropped to such fuel economy levels is when my injectors were shagged, the o2 sensor was still ok but definitely a tad slower than the new genuine o2 sensor I replaced it with.
So as I believe I've said before...
Check for vacuum leaks, ensure o2 sensor and injectors are in good condition and motor in good condition.
And drive sensibly, short shift around 2500rpm and use a little more throttle to get the car moving, driving like this its also critical your tuner doesn't have the afr's dropping to flat 12's as soon as any boost is made.
From factory my rb20det driving as such would hang in closed loop until roughly 2psi was being made, so it was running lean, possibly why it consistently returned just under 500km's to a tank.
But as with everything there are bad cars and good ones... Its just finding what is causing the problem. R33's suffer the poor fuel economy problems much more often than the R32's, its not displacement as I've noticed no real noticable difference and i'm 1ltr over a 2ltr. :)
  • 7 years later...
Most of you guys are getting good economy! My 25/30 is running 19/100km no matter how I drive.
That's on a 25 tune @5psi. On the wideband it shows 14.5-15.8 in closed loop but gets right up to 11.1 at wot.
Will hopefully get better when I get my pfc and sard 800cc fitted and tuned.
I think the roads to good economy are CR injectors and gearing . An RB30 with at LEAST 9.5 static CR should make real good part throttle torque . I also think good injectors like EV14s help heaps because they have fine control (if tuned properly) at short pulse widths .
Most R series Skylines were geared to suit the std RB20/25/26 and Japanese roads , depending on the lump you removed the gearing can be pretty short for a 3 litre . I don't think any turbo R series was taller diff wise than 4.1 and a 3.9 would allow you to better use the extra part throttle torque . Note the difference in rear gearing between some JDM and some Aus spec S series cars , 4.1 to 3.7 in one case from memory .
Lastly and very importantly , turbine back pressure . If the turbine/housing combination is small this hurts consumption too .
A .
A .
That's why I am still looking for an R34 GTR non v spec diff (3.545) not just for the fuel economy but more for more restful cruising at 110km/hr
Nick, isn't your in a patrol? The extra weight would make a huge difference.
I am getting just over 13 driving to and from work mostly (12ks each way) with my auto rwd Stagea. I have been meaning for ages to tweak all of the cruise section of my tune but still haven't.
800s because they come up cheap, New still sealed in box's for $200.
If something better Sized shows up for sale I'll get them, I really only wanted bigger than stock- like 400-500cc
Yeah it's in a patrol, on 35s and 6in lift so she's pretty aerodynamic!
And it has 4.94 diffs.
It does 2550rpm at 100km.
And it weighs 2200kg, probably bit more with a full tank.
Edited by nicksamaniac
Why are you getting Sard 800 injectors? They won't help your economy. Are you going for 500KW?
500Kw at least!
I want to be able to lift a wheel whilst overtaking at 100km/hr!
But more seriously I was just gonna put it on the Dyno and lean on it (to a safe enough level) and see what it makes.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
