How many Stagea owners does it take...
306 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
just picked up my new beast yesterday afternoon, cars stock apart from the DAYZ body kits...its a 1998 Nissan Stagea (Series 2).
Got some plans for it now :P
Cheers,
Corey
That is AWESOME! I want your rear bar :(
Looks lowered? Bodykit is completely factory though (well, Dayz factory) - the Dayz sideskirts, front bar and rear bar were all options. Got a dolphin front grille which isn't standard though (as some people already pointed out).
  • Replies 292
Posted Images
hey guys, got myself a Stagea about a month ago and thought it was about time i introduced myself here in the stagea section. i've just come from owning a r32 for the last 3 years and thought it was time for something newer and different, but still a RB nissan.
the car is a fresh import, 99 S2 auto, DAYZ kit, dual sunroofs, and all stock apart from the mags it came in with, which i plan to eventually change after i get it lowered.
here is some pics i took.
Cheers
Josh
Got my Stagea a few days ago. Its a s2 with most of the options to increase luxury and reduce performance :domokun: Its got leather interior, xanavi unit, heated seats, cold area options, twin sunroofs etc. Its also got an autech (im pretty sure) front on it, but I dont what the rear bar is yet.. any ideas? Its also got a different spoiler to most I've seen with a brake light in it. The wheels are 17's and it has adjustable tein suspension (a nice bonus to find!) It also had a mystery button on the dash which after some fiddling turns out to be a 'tv works in drive mode thingo' button. *happy dance* Im trying to decide whether I should lower it a bit or not yet, curse you whoever came up the the speed hump idea.... Anyways, here's some pics!
Sorry dialuppers!
Just in... 2000 S2 Pearl White in Adelaide... this is the (filthy) beast as it rolled off the delivery truck this afternoon:
It's a Prime Edition and this pretty much sums up why I like Primes:
5 years looking 3 months waiting... finally here!
Cheers guys I have spent countless hours being entertained by your posts & reading useful information. I don't think there's a better Stagea resource on the Internet (in English anyway!)
Regards,
DaveB
congrats on the rego from the brotherhood :D
First post here.
I've had a 97 Stagea RS-Four for about a year now:
R34 GT-R face with genuine aluminum hood, FRP fenders and bumper
R34 GT-R wheels
R32 Type-M calipers with slotted/drilled rotors
HID headlights (modified to fit non-HID headlights- the Xenon R34 headlights are $$$)
Cusco front camber arms
Cheap Ebay rear camber arms
Tein coilovers up front
Apex'i coilovers out back
Kouki taillights
HKS Super Dragger (quiet) exhaust and pod filter
Plans are 5 speed swap (got everything but the console, which I plan on ordering from Nissan)
FMIC
Down pipe, front pipe, test pipe
That's about it. This is my wife's daily, so keeping it rather simple.
Pictures of when I first bought it, I guess I need to take some new ones:
just a quick one....is it worth putting Car model or some thing up the top to say how many of each type of Stag there is eg.
34 Series 1
34 Series 2
34 rs260
M35 rs
M35 AR-X
M35 Axis
Or is this a pain in there arse to do?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
