How many Stagea owners does it take...
306 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
just picked up my new beast yesterday afternoon, cars stock apart from the DAYZ body kits...its a 1998 Nissan Stagea (Series 2).
Got some plans for it now :P
Cheers,
Corey
That is AWESOME! I want your rear bar :(
Looks lowered? Bodykit is completely factory though (well, Dayz factory) - the Dayz sideskirts, front bar and rear bar were all options. Got a dolphin front grille which isn't standard though (as some people already pointed out).
  • Replies 292
Posted Images
hey guys, got myself a Stagea about a month ago and thought it was about time i introduced myself here in the stagea section. i've just come from owning a r32 for the last 3 years and thought it was time for something newer and different, but still a RB nissan.
the car is a fresh import, 99 S2 auto, DAYZ kit, dual sunroofs, and all stock apart from the mags it came in with, which i plan to eventually change after i get it lowered.
here is some pics i took.
Cheers
Josh
Got my Stagea a few days ago. Its a s2 with most of the options to increase luxury and reduce performance :domokun: Its got leather interior, xanavi unit, heated seats, cold area options, twin sunroofs etc. Its also got an autech (im pretty sure) front on it, but I dont what the rear bar is yet.. any ideas? Its also got a different spoiler to most I've seen with a brake light in it. The wheels are 17's and it has adjustable tein suspension (a nice bonus to find!) It also had a mystery button on the dash which after some fiddling turns out to be a 'tv works in drive mode thingo' button. *happy dance* Im trying to decide whether I should lower it a bit or not yet, curse you whoever came up the the speed hump idea.... Anyways, here's some pics!
Sorry dialuppers!
Just in... 2000 S2 Pearl White in Adelaide... this is the (filthy) beast as it rolled off the delivery truck this afternoon:
It's a Prime Edition and this pretty much sums up why I like Primes:
5 years looking 3 months waiting... finally here!
Cheers guys I have spent countless hours being entertained by your posts & reading useful information. I don't think there's a better Stagea resource on the Internet (in English anyway!)
Regards,
DaveB
congrats on the rego from the brotherhood :D
First post here.
I've had a 97 Stagea RS-Four for about a year now:
R34 GT-R face with genuine aluminum hood, FRP fenders and bumper
R34 GT-R wheels
R32 Type-M calipers with slotted/drilled rotors
HID headlights (modified to fit non-HID headlights- the Xenon R34 headlights are $$$)
Cusco front camber arms
Cheap Ebay rear camber arms
Tein coilovers up front
Apex'i coilovers out back
Kouki taillights
HKS Super Dragger (quiet) exhaust and pod filter
Plans are 5 speed swap (got everything but the console, which I plan on ordering from Nissan)
FMIC
Down pipe, front pipe, test pipe
That's about it. This is my wife's daily, so keeping it rather simple.
Pictures of when I first bought it, I guess I need to take some new ones:
just a quick one....is it worth putting Car model or some thing up the top to say how many of each type of Stag there is eg.
34 Series 1
34 Series 2
34 rs260
M35 rs
M35 AR-X
M35 Axis
Or is this a pain in there arse to do?
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
