Just lucky you dont work in a supermarket daz >.<
yes you are right, but i am in retail sort of we sel building supplies, but we get off bcoz the builders dont work over this period anyway. im just going to sleep for 10 days, till i go back to work on the 2nd i think....have i got enough simpson episodes on dvd to keep me going lol seasons 1-6, i mite just have enough.
so tired :sleep: i hate christmas time, because its busy, i have to work extra coz my staff are idiots, and bad things always happen :rant:
tis the season to be jolly. whoever said that deserves a slap in the face, followed by a chat with Isaac's lawyer *pulls basbeall bat out of boot* thanks isaac :happy: i knew i'd find a use for him!
i thought this was supposed to be the time of giving, not taking! it seems all i do at christmas time is watch as people take :pirate:
oops, there goes my car........oh and there goes my office's money.........yeah sure, you can take double rent money this week, why not.........of course i dont mind working back for free because you cant do your job :) AAARRRRRRGH!!!!! and people wonder why i tell them to "go f**k yourself!" when they wish me a merry christmas :happy:
do i have a sign that i cant see that says please use and abuse me over the holiday season?
*sigh* well thats my rant, now i'm tired. christmas can kiss my ass :down:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
