Bahahahahah Wagamama best name ever!
:blush: So I see you've got a red '34 eh? noiiiceee!!!
OMFG.....
a new page :thumbsup:
ROFL!! Farken cassic Joe!
"Whoretown - Now Interest Free"
Kinda says it all doesn't it...........
Bahahahahahaha ( yeah took me a while to get it too though.... :) )
Oh, and morning Whorebags!!! :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
