hey guys im currently chasing a injector resistor pack for a rb26, but its proving difficult to find one. so im thinking do any other model skylines, or nissans use the same resistor pack????
or if anyone knows anyone with one for sale let me know plz :P
also i need the detonation sensor plugs section of the main engine harness because i got sold a harness without this bit, if anyone has one lying around.
thanks
Brad
https://www.sau.com.au/forums/topic/119532-rb26-injector-resistor-pack/
A new resistor pack is about $150 from Nissan.
There's only one car I've found that uses the same resistor pack and that's the Cima from about 1989 using the VG30DET. Of course finding one of those is even harder.
The good news is that R30 Skylines and 280ZX had a resistor pack that can be adapted for the purpose. The connector is different, but if you can find a wreck with a complete loom, you can get both halves of the connector and adapt it to to the RB26 loom. The best places to get things like this are self serve wreckers.
If you get stuck I have a spare R30 pack with connector.
Hi, you can also simply buy 6 X 10 ohm resisters from JayCar or Dick Smith. Then wire them in series, one for each injector. You can do that as a pack, with the 6 resistors all shrink wrapped together, or one located at each injector.
:P cheers :D
so basically something like this wired in between the injector and main wiring harness with work with no problems at all and for the minimal cost? id imagine they would need to be well heat wrapped though. does the wattage matter at all?
http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/R1626
seems rediculous that nissan sells them for 150 (in nz its around 250) considering the cost
Edited by SirRacer
Yep I run the R30 resistor pack.
Its very closely rated to that of the GTR resistor pack, from memory the GTR resistor pack measures up at 5.8ohms vs the R30 pack at 6.3ohms. The connector the resistor pack uses is the usual motormates/sprint auto shop type that sell for around $3.95. So there is absolutely no need to grab part of the loom, simply grab an Navara 8pin plug from your local auto shop and use one half of it.
I looked in to running cheap dicksmith/jaycar inline resistors but was put off after doing the watt calculations.
One won't see any problems running the cheap 5w resistors running around the street but if it hits the track or sustains high rpm for long periods of time... well.. I wouldn't risk it.
I then looked in to the 15-17w resistors and discovered they are mighty expensive. The rotor boys also have been known to make their own resistor packs and they most definitely do not use the cheap resistors, they use the 15-17w items, for six of these suckers you are look at slightly over $100. The rotor boys use 6.5ohms resistors, not 10ohms as the calcs would suggest. Interesting, ecu's have head room. >_<
$150 for a bran new resistor pack from nissan?
They are generally $100-$150 second hand at the wreckers.
And a few pics for those interested what the R30 resistor pack and plug looks like.
I grabbed part of the loom before I discovered the local autoshops sell the exact same plug. :nyaanyaa:
  • 1 month later...
I then looked in to the 15-17w resistors and discovered they are mighty expensive. The rotor boys also have been known to make their own resistor packs and they most definitely do not use the cheap resistors, they use the 15-17w items, for six of these suckers you are look at slightly over $100. The rotor boys use 6.5ohms resistors, not 10ohms as the calcs would suggest. Interesting, ecu's have head room. :)
I grabbed part of the loom before I discovered the local autoshops sell the exact same plug. :D
what is the main issue cubes. is it simply the resistor being affected by heat??
sydneykid is pretty spot on, so sydneykd would you mind explaining cubes' theory and your opinion of it.
will the computer also be affected by the different ohms?
Do some googling and read up on the theory behind it your self, much more rewarding. :D
Yes Roy is on the ball... Just get the correct items from the word go.
By the time you by a set of gtr injectors then have them cleaned... Your only a few hundred off a set of nice shinny new items from nengun.
EDIT: Ok I've done a quick google. Explains all you need to know.
Scroll to just past half way.
http://www.megamanual.com/v22manual/minj.htm
For your own curiosity type in the gtr injector specs... And take very close note of what ohm resistors they recommend you use.... Nissan got it spot on from factory, well close enough. :(
Which is why you don't use 10ohm resistors; its not as simple as high imp resistance - low imp resistance = the resistors to use.
Don't stuff around, use what or damn close to what Nissan use, they are not silly people they know what they are doing, stick to the ~5.8 resistors, 6.3ohms from the r30 is bugger all and works perfectly fine on mine and many others.
If Nissan thought it was sufficient to use crappy little 10w resistors I'm damn sure they would have done so instead of using the bulky big arsed resistors they do.
Do some googling and read up on the theory behind it your self, much more rewarding. :blush:
For your own curiosity type in the gtr injector specs... And take very close note of what ohm resistors they recommend you use.... Nissan got it spot on from factory, well close enough. :yes:
cheers, i got my 700cc injectors for 600 so i think a resistor pack is definitley worth the trouble :angry:
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
